This project is what prompted me to quit lurking in the shadows and join this site. Here is a link to what I have done so far. It will help to the big picture of what I am doing.
A guy told me that he ground that corner of the block off, used a factory starter and just ran the four bolts for 15 years. If I do grind off the block to allow for the FE starter I am going to add the fifth bolt in there some how. The block is just under 9/16" thick and an 1 5/8" deep where the bolt would go. The transmission bolts are 7/16". That would put a thin skin of cast iron on two sides of the bolt. I have a few ideas on how to get around it but I would rather build the block up for a full size factory bolt. If I do cut up a couple of bell housings everything would be torqued together and then cold welded 1/4" to 1/2" at a time.
Question: What are your suggestions for building up the block?
Thanks
Thanks
