New ramp fpr boat club
  • New ramp fpr boat club
Name:	Ramp before.jpg
ID:	598737Click image for larger version
Name:	Existing hinges.jpg
ID:	598739Click image for larger version
Name:	Left bracket.jpg
    Was asked to help rebuild an access ramp for a local canoe club.
    Original wood ramp had been washed away in a storm last year.
    Not much was left to give ideas for a new one.
    The old ramp was hinged at the top end so the lower end could rise and fall with river levels.
    A big concrete block with 2 pieces of 2" IPS pipe served as the hinges.
    Doesn't look it but the block is securely attached to the foundation.
    The ramp is used for canoe and kayak access to the river so it will only see foot traffic.
    Made up 2 new brackets to hold 2 x 8 pressure treated lumber for the
    rails and used the old pipes for a hinge.
    Used 1/4" stainless plate for the brackets.
    3" x 3" x 1/4" alum angle was used to connect the side rails to cross members.
    1/2" bolts for all connections and 5/4" pressure treated decking.
    Was asked why I used stainless and said I hate call-backs and that by the time it needs replacement,
    I'll be long gone and it will be someone else's problem.
    More photos
Name:	Right bracket.jpg
ID:	598742Click image for larger version
Name:	Deck frame.jpg
ID:	598744Click image for larger version
Name:	Finished ramp2.jpg
      Nicely done.
