Mounting I-beam and chainfall over lathe
    Originally posted by Meltedmetal View Post
    While they do protect the wheels from the stops those turned in ends are there to catch the carriage with a minimum of drop should there be an axle failure on the carriage.
    ---Meltedmetal
    That makes sense. You learn something every day.
    -Don
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Yeah, we were advised by the powers that be that our antique carriages could not fall more than 1 inch should an axle fail, so we had to retrofit them to comply. Probably a good idea as we were moving 400 lbs.pots of molten iron with them. We never needed the safety device but it is nice to know they were there.
      ---Meltedmetal
      ---Meltedmetal
        ---Meltedmetal
        I just walked through our training area. One chainfall trolley had a factory trolley with a drop stop mounted on it as shown below.
        16. Factory mounted drop stop
        Click image for larger version  Name:	16. Factory mounted drop stop.jpg Views:	0 Size:	38.8 KB ID:	598861
        Two had angle iron drop stops welded to the carriage.
        17. shop repaired drop stop
        Click image for larger version  Name:	17. shop repaired drop stop.jpg Views:	0 Size:	58.3 KB ID:	598862
        And one trolley didn't have a drop stop at all.
        18. Trolley without a drop stop
        Click image for larger version  Name:	18. Trolley without a drop stop.jpg Views:	0 Size:	62.1 KB ID:	598863
        Here is what I could find.
        19. Safety Lug definition
        Click image for larger version  Name:	19. Safety Lug definition.jpg Views:	0 Size:	100.0 KB ID:	598864
        I had trouble finding a standard that required this for trolleys.
        Do you know which standard applies?
        Our application is just lifting parts of robots.
        No hot metal is involved.
        -Don
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          I don't know. I'm in Canada so the standards are not likely the same. IIRC we were instructed to make the alteration by the CSST inspector(equivalent to your workman's compensation inspectors, maybe) It was a new installation for us from a foundry that closed so it had to meet the current specs. They never came back to check but it's not a terrible idea and reasonably cheap to do.
          https://www.crane1.com/about-us/blog...-requirements/
          Perhaps someone in your organization thought it might save some expensive parts from hitting the floor.
          ---Meltedmetal
          ---Meltedmetal
