Supercharger Casting Repair
  • ryanjones2150
    That's what I do, hose it off, wipe it down with a clean rag, dry it off.
  • FusionKing
    With alumi-brite we rinse with water only.....a lot of water
  • sledsports
    Looks great Don!
  • tarry99
    Yep..........then rinse with water.........let it try.
  • snowbird
    Q ? when using muriatic acid on alu, do you neutralize after, prior to welding? i uze that for zinc plating removal on bolts and nuts and neutralize with sodium bicarbonate (arm&hammer) type..
  • Ltbadd
    Originally posted by FusionKing View Post
    We use aluma-clean and aluma-brite by the gallon.
    Truckers use it to clean trucks. Part stores carry it for around $15 a gallon. I sometimes buy it by the case and use it full strength with a spray bottle.
    Ok thanks, I remember this stuff, used it many moons ago...
  • FusionKing
  • Ltbadd
    Thanks!
  • tarry99
    Sorry.....been away............get yourself some disposable gloves.....and eye protection......and a few of those little acid brushes plumbers use for applying flux to copper before they solder it.......a little goes along way........might need a second coat if it's real dirty...........Home Depot sells some........body shop supplies or a good welding shop should have it.............Good Luck!
  • Ltbadd
    Originally posted by tarry99 View Post
    I use acid for cleaning prior to welding aluminum......especially when it's been around oil and grease.
    Can you provide a link, or brand name of this product?
  • FusionKing
    We do quite often as well. Makes it look brand spankin' new
  • tarry99
  • Don52
    I appreciate all of your comments.
    -Don
  • Oldgrandad
    Nice Job, Great photo's. The step by step is wonderful, shows those just breaking into the biz the RIGHT way to do things. Short cuts don't cut it. #13 stating you had to grind out welds and redo them, happens a lot with auto repairs. Just another detail not often mentioned (like it doesn't happen ).
  • Ltbadd
    Good work Don, very thorough
