The Correct Answer is "Yes Dear" (Modifying a bird feeder pole)
  • The Correct Answer is "Yes Dear" (Modifying a bird feeder pole)
    Do you ever encounter a 15 minute jobs that turn into a three hour job?
    My wife asked me to install a pole for the bird feeder that she purchased. It didn't sound like a welding job but the pole was so short, that she couldn't see the birds at the feeder, which is the whole point of having a bird feeder. I spliced the shaft and then I decided to move the cross brace up so the there would be 16 inches in the ground instead of just 10 inches. I settled on 16 inches because I had underground electrical conduit at 18 inches and I didn't want to hit it.
    1. Removing zinc plating with hydrochloric acid (or Muriatic acid from Home Depot)
Name:	1. Removing zinc plating.jpg
    2. Zinc plating removed (to avoid poisonous fumes when welding)
Name:	2. Zinc plating removed.jpg
    3. Chamfering shaft (to get full penetration)
Name:	3. Chamfering shaft.jpg
    4. Cutting Shaft
Name:	4. Cutting Shaft.jpg
    5. Aligning shaft
Name:	5. Aligning shaft.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    6. Tack TIG welding shaft (because I have better control of the puddle)
Name:	6. Tack welding shaft.jpg
    7. Shaft TIG welded
Name:	7. Shaft welded.jpg
    8. Cross Brace MIG weld 1 (because it is faster)
Name:	8. Cross Brace weld 1.jpg
    9. Cross brace MIG weld 2
Name:	9. Cross brace weld 2.jpg
    When I went to install the squirrel shield I noticed that the bracket that came with the squirrel shield was too large to fit on the pole. You might think if you purchased both at the same store at the same time that they would fit, but you would be wrong. To solve the problem I machined a Black Delrin plastic spacer to take up the gap. The new spacer does look like it belongs with the bracket.
    10. Boring and cutting off spacer
Name:	10. Boring spacer.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      11 Splitting spacer
Name:	11 Splitting spacer.jpg
      12. Split spacer in place
Name:	12. Split spacer in place.jpg
      13. Squirrel shield installed
Name:	13. Squirrel shield installed.jpg
      14. Bird feeder installed
Name:	14. Bird feeder installed.jpg
      You can see my garage in the background. The part that sticks out in the rear of the picture is my new addition that I have been working on for the past year. The status is that I am almost finished with installing the insulation.
      -Don
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Might've got that insulation done if you weren't choppin up a bird feeder....
          You are probably right I have been working on insulation today. I plan to finish the last three batts of insulation today.
          -Don
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Good size add-on there.
              The floor is 15' x 38'
              -Don
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                With that much more room, you get to buy more stuff!
                  Yep, that's the plan.
                  Miller Thunderbolt
                  Lincoln LE 31 MP
                  Lincoln 210 MP
                  16" DuAll Saw
                  15" Drill Press
                  20 Ton Arbor Press
                  Bridgeport
                    That's great Don, looking forward to your in detail exploits!
                    Richard
                    West coast of Florida
                      Yes, 15 minutes turns into 3 hours. That's not the exception that's the rule. LOL. Then the wife say's What is taking SOOO long. I often wonder how the average Joe gets anything put together. I seem to buy brand new broken or just brand new doesn't go together like it should, stuff. Don you did a great job with that bird feeder. The addition is fantastic also.
