Western Snow Plow Stub Shaft Repair
  • FusionKing
    Originally posted by Don52 View Post
    I charged about half of that. Keep in mind that you are the master who works on high end stuff. I am the apprentice that works on low end stuff. By the way I really like your swim platforms and tuna towers.
    -Don
    I just looked and figured it would take about 2 hrs. fooling around and then added 25 for good measure on junk like grinding wheels and drill bits or whatever. You're too cheep.
    Thanks for the kind words, but I really could use a guy like you here.
  • FusionKing
    Originally posted by ryanjones2150 View Post
    If you're the apprentice of low end stuff, that must make me the pee-on of junk....
    BAHAHAHA
  • ryanjones2150
  • Don52
    Originally posted by FusionKing View Post
    So I'm gonna say $225 ish?
    -Don
  • FusionKing
  • Don52
    The last step was mounting the plow back on the truck.
    The large cotter pin on the right attaches the lower plow frame to the truck frame bracket. The cotter pin to the left goes in the stub shaft, which is the one that we repaired. This cotter pin keeps truck frame bracket link from falling off the stub shaft on the upper plow bracket.
Name:	10. Pin in place under bumper.JPG
    I did have trouble opening up the existing hole in the shaft after I got some weld on the entrance to the hole on both sides.
    My first approach was trying to drill the hole open.
    The drills caught and broke.
Name:	11. Broken drills.JPG
    My next attempt was a carbide burr.
    The burr caught and broke.
Name:	12. Broken carbide burr.JPG
    My final approach was to use a small grinding stone on my Foredom shaft grinder.
    This worked fine, but I did wear out the stone.
Name:	13. Worn out grinding wheel.JPG
    I can be quite competitive repairing parts of snow plows, because the parts are pricey.
    My customer did want it in service as soon as possible with snow predicted for the next weekend.
    A new lift frame costs $366.69, but you would still have to strip the lights, hydraulic hoses and cylinder from the old one.
  • Don52
    The next picture shows grinding the stub shaft to clean it up in preparation for welding.
Name:	5. Grinding stub shaft.JPG
    The following picture shows wire brushing the stub shaft to remove the rust.
Name:	6. Wire wheel brushing stub shaft.JPG
    I built up the ends of both of the stub shafts with weld.
Name:	7. Welded extension on the stub shaft.JPG
    I dressed the weld in preparation for drilling.
Name:	8. Shaft ready for drilling.JPG
    Then I drilled a new hole for the cotter pin.
    The following picture shows the cotter pin in place in the new hole of the newly built up shaft.
Name:	9. Cotter pin in place.JPG
  • Don52
    started a topic Western Snow Plow Stub Shaft Repair
    My customer just purchased a used Western snow plow. The pump worked fine, the blade had a lot of life left and the hoses were new last year. The only problem was that the stub shafts that attach the upper plow bracket to the truck frame bracket were cut off for some reason.
    The location for stub shaft that needed to be repaired can be seen in the following exploded view.
Name:	0. Exploded view showing stub shaft.jpg
    The 1st stub shaft was so short that it even lost the cross hole for the cotter pin, so there was no way to keep the truck frame bracket link from falling off the stub shaft of the upper plow bracket.
    To get the plow to my house, my customer had to ratchet strap around the truck frame bracket link to hold it onto the stub shaft. As you can see in the following picture the stub shaft is just barely flush with the truck frame bracket link.
Name:	1. Strap holding upper plow bracket to 1st stub shaft.JPG
    in the second picture truck frame bracket link was removed so that you can see the end of the first stub shaft, which was so short that there was no longer a hole for the cotter pin.
Name:	2. Truck frame bracket link removed from 1st stub shaft.JPG
    On the 2nd stub shaft there was only a little bit of shaft beyond the hole to support the cotter pin. My customer wanted this shaft also built up because he was worried that the cotter pin might pull out through this thin wall on the end of the stub shaft. This picture shows the truck frame bracket link on the 2nd stub shaft.
Name:	3. Pin close to end of 2nd stub shaft with truck frame bracket link in place.JPG
    The next picture shows the truck frame bracket link removed.
Name:	4. Link on 2nd stub shaft removed.JPG
