My customer broke off the right hand bracket that supported the mower deck. I believe that the problem was that at some point in the past 5 years he hit something hard. Figure 3 shows a force diagram which would explain the dent that I observed in the top of the mower deck. The first step was heating up the dent and pounding it out against a large piece of steel.
X-Mark Mower Deck Repair
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
BridgeportTags: None
The 1/4" support bracket was broken off clean and also had a crack about halfway through. I grooved and welded up this crack first so that the bracket had a chance of sitting flat on the mower deck. Next I clamped the bracket straight and pulled in the bottom of the bracket flat on the mower deck. It looks like a lot of clamps, but I added them one by one until the bracket was exactly where I wanted it and straight. I welded up the spider cracks and then tack welded the bracket in place. Next I welded up the groove in the 1/4" plate of the broken bracket to the piece still attached to the mower deck.
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
- Likes 1
I added an additional bottom plate for additional support and hopefully to help stop denting of the top of the mower deck. I added an additional weld to attach the bottom plate of the broken bracket to the sides of the mower deck for good measure. I decided to beef up the 1/4' plate that broke with a fish plate, which I set back from the edge of the original 1/4" plate by about 1/5". The last step was priming and painting it. My shop was 50 degrees F so I used my 1000 watt shop lights and my 800 degree heat gun to help the paint to set up before we reinstalled the deck on the tractor.
-Don
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
- Likes 1
Originally posted by smawgmaw View PostWhat is the "gun" in the last two pics? I am not familar with it. Is it a type of powder coating system or heat gun?
-DonSmith Oxyacetylene Torch
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
Originally posted by ryanjones2150 View PostDid you stop drill the cracks running all over the place?
As usual, excellent job documenting the repair.
Lincoln LE 31 MP
Lincoln 210 MP
16" DoAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
