Sub-Frame Repair on a 2010 Ford Flex
  • Sub-Frame Repair on a 2010 Ford Flex
    This week's project was to repair the attachment point for the steering rack on the sub-frame of my friend's 2010 Ford Flex, which he plans on keeping a few more years. I was surprised that it rusted completely though in eight years. My friend does lives one mile out on a dirt road, so dirt and calcium chloride that they put on the road to keep down dust, probably contributed to it. The following picture shows the rusted through steering rack attachment point on the sub-frame.
    1. Rusted rack attachment point
Name:	1. Rusted rack attachment point.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    In the following picture you can see a schematic of our approach. We manufactured a steel cup, which will serve as the new attachment point for the rack on the sub-frame. The steel cup is bolted to the sub-frame. The steel cup is fillet welded on both sides to a plate, which is in turn welded to the sub-Frame.
    2. Schematic.
Name:	2. Schematic.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      We manufactured a steel cup in the lathe. Notice the 1-1/2" drill bit. A 7-1/2 HP lathe has little respect for steel.
      3. Making steel cap
Name:	3. Making steel cap.jpg
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        We made radial cuts in the plate and formed it to the shock tower. Next we bolted the steel cup to the sub frame. We held the plate in place and tack welded it to the steel cup. Finally we removed the plate/cup assembly and welded it out on both sides in a vise. Click image for larger version
Name:	4. Welding steel cap to plate.JPG
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          We re-assembled the cup/plate assembly to the sub-frame. Then we welded the assembly to the sub-frame. The last step was to weld up the radial saw cuts.
          5. Plate welded in place
          Don
          Click image for larger version  Name:	image_36564.jpg Views:	1 Size:	64.7 KB ID:	591933
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            Looks good. What process did you use? It looks clean. Like maybe pulse-mig.
            I built some cups like that out of DOM tubing and then welded a plate on the end to cap the cup. Seeing what you did does make me want to find a lathe.
              I welded the cup to the plate using short circuit MIG using .035" wire on the SP-250 welder.
              I just welded it continuously tracing small "U" shapes.
              For welding the plate to the sub-frame I short circuit MIG welded it using the LE31MP welder, because I keep .025" wire in it.
              I manually pulsed by pushing the trigger and waiting until the puddle cooled off slightly and then advancing slightly and repeating the process.
              -Don
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                You always do such a good job of taking pictures. I definitely suck at it.
                  Grasshopper, you must see as the camera does...
                  Richard
                  West coast of Florida
