Shrink a bearing by welding to remove
  • Shrink a bearing by welding to remove
    The wheel bearing on my customer's baby stroller for jogging failed and all of the balls came out leaving the outer race a heavy press fit in the hub. The bike store said that they would have to grind through the outer race to remove it, but they were too busy to deal with it.
    I used an ID puller to grip the ball race of the bearing because the bearing was up against a shoulder and I couldn't get behind it. I tried with the setup shown below but it wouldn't budge.
    1. ID bearing puller
Name:	1. ID bearing puller.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Next I tried to use a more rigid backup to prevent the spokes from acting like springs, which reduced the impact load as shown below:
    2. Rigid backup
Name:	2. Rigid backup.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      This also didn't work, so I used a TIG torch with a small diameter conventional nozzle to melt the outer race in spots and allow it to shrink as the metal cooled off. I didn't actually add any metal. The TIG setup is shown below:
      3. TIG melting spots on outer race
Name:	3. TIG melting spots on outer race.jpg
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        I used the "Solid backup" shown in picture #2 and the race came right out as shown below:
        4. Race removed from hub
Name:	4. Race removed from hub.jpg
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Here is what the inside of the outer race looked like with the TIG melted spots. The ID of the hub wasn't affected.
          5. TIG welded outer race
          • Have you ever used this or a similar method to remove a bearing or hub?
Name:	5. TIG welded outer race.jpg
          Miller Thunderbolt
          Lincoln LE 31 MP
          Lincoln 210 MP
          16" DuAll Saw
          15" Drill Press
          20 Ton Arbor Press
          Bridgeport
            No I haven't, good thinking Don
            Richard
            West coast of Florida
              Yup, I usually just run a bead completely around the inside of the race with 6011 and let it cool. Works pretty slick.
              Nice job helping out the jogger.
              ---Meltedmetal
              ---Meltedmetal
                Saw this posted on another site.
                A FEW OF MY TOYS !!!
                MX Linux
                LinuxMint
                Miller Roughneck 2E
                Lincoln Weldpak 100
                Gianttech Arc 200
                  A few years back I welded for a large compressor company. The guy who rebuilt the screw compressors would bring me the rotors to weld a bead on the race to remove it. I would run a bead and he would stand them up and the race would just fall off...Bob
                    This is done all the time to remove worn steel bushings in excavator booms. A pass or two inside the race with your stick welder and whatever rod happens to be in it loosens the bushing.
                      I don't feel like typing much so I'm going to keep it short, sweet and to the point. It's not magic it's knowledge being applied.
                      It's the result of restrained expansion. Iron and steel will when heated expands in all directions and when cooled shrink in all directions. While restraining it's expansion in one direction, it will still contract from that direction when cooled. It's condition is said to be "upset" as a result.
                      That my friends is the why.
                      Image result for weld expansion and contraction
                        I have that same inside puller thing. They never seem to work very well. Maybe I'll add heat next time.
                          Heavy duty bearing races in trucks & trailers........if the bearing is already shot.......allot of time can be saved by just running a bead a 180 degrees apart ..........falls right out....
