Injector Tip Modification
  • Injector Tip Modification
    These injector tips are used to squirt paint against a distributor inside a bell cup on a paint robot for painting cars.
    For prototype testing we required a longer injector tip.
    We wanted to test it right away.
    So I cut the end of one existing injector tip and the base off a second one and welded them together to make the longer tip that we required.
    The following pictures tell the story.
    1. Half of two injector tips
    2. Welding the halves together
    3. Opening up the center hole
    4. Close up of lathe chuck
    5. Longer tip done
Name:	1. Half of two injector tips.jpg
Name:	2. Welding the halves together.jpg
Name:	3. Opening up the center hole.jpg
Name:	4. Close up of lathe chuck.jpg
Name:	5. Longer tip done.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
