Welding Aluminum Bracket for Ancient Dump Truck
  • Don52
    started a topic Welding Aluminum Bracket for Ancient Dump Truck
    During disassembly by mistake my customer broke off the ear of the bracket, because he didn't see the last bolt. After I cleaned up the casting I noticed that there was a second crack. I grooved out the 2nd crack from both sides for 100% penetration and filled it up with weld. When I was grinding the broken off ear, the carbide burr caught it and threw it from the vise, never to be found again, so I had to make a new one. Fortunately I had the welding and machining fixture done by that time, so I new where to locate it. The following pictures document my progress.
    1. Cracked Bracket
    2. Cracked in two places
    3. Outside of 2nd crack
    4. Inside of 2nd crack
    5. Making welding and machining fixture
Name:	1. Cracked Bracket.jpg
Name:	2. Cracked in two places.jpg
Name:	3. Outside of 2nd crack.jpg
Name:	4. Inside of 2nd crack.jpg
Name:	5. Making welding and machining fixture.jpg
  • Oldgrandad
    Don't worry you'll find that piece, in a year or so.
  • Don52
    Originally posted by Oldgrandad View Post
    And 4 hours later your finished. Real nice work that should hold for another 30 years. I like the plate (fixture) to keep it all lined up.
    You are absolutely right, it would have taken four hours, except when I bevel ground the ear in the vise, the carbide burr caught it and sent it to an alternate universe. I looked for it without success for one hour.
    I used the plate to hold everything flat and in location while I welded it. The riser tube on the left hand screw allowed me to weld the ear to the bracket, while it was being held.
  • Oldgrandad
    Originally posted by MAC702 View Post
    Looks like something the customer tells you will take ten minutes to fix.
  • MAC702
  • Don52
    Here are the last two pictures.
    I will try to get a picture of the truck when I drop off the repaired bracket.
    11. Bracket welded and machined
    12. Close up of welds
Name:	11. Bracket welded and machined.jpg
Name:	12. Close up of welds.jpg
  • Don52
    Here are some more pictures:
    6. Bracket mounted to fixture
    7. Making new ear
    8. Carbide burr to bevel casting
    9. Standoff for welding ear
    10. Spotfacing excess weld
Name:	6. Bracket mounted to fixture.jpg
Name:	7. Making new ear.jpg
Name:	8. Carbide burr to bevel casting.jpg
Name:	9. Standoff for welding ear.jpg
Name:	10. Spotfacing excess weld.jpg
