Building a custom Firepit grill/grate for friend
  • Building a custom Firepit grill/grate for friend
    So need some advice on what or how i can do this.. I have the material and design idea for it.. but what im having a hard time calculating is the length of round rod i need in order to make a 28" round trim for the grate.
    He has a fire pit in his backyard.. which right now he uses just to light at night and have a nice fire for his wife and family.. BUT he would also like to use it to cook from time to time.. so i wanted to add a round rod to the grate to clean it up and keep things safe from sharp edges.
    I will be buying the tube roller to create the circle, but not sure how to determine how long the rod needs to be in order to get a 28" or close circle.
    Any suggestions or help or links to materail on how to determine.
    It sounds as though you want to calculate the circumference of a circle, if so it's the diameter times pi. 28 * 3.1416 = ~88"
    However I think you'll need to factor in the tube diameter that you intend on using
    Richard
    West coast of Florida
      i going to see about sticking with 1/4" round and 1/4" grate, something simple, but reinforced under the grate with their family initials. Still working on the design..
        (Diameter + thickness of the rod) x 3.14
        example: (24 + .25) x 3.14= 76.145
        ....in inches of course.
        Give that a shot.
          Just to clarify upon the above. Take the inside diameter of the circle you wish to make from rod/tube plus the diameter of the rod. This gives you the centerline of the rod/tube when formed. Multiply times pi. This will give you the stretch out of the material. When you roll pcs. you will end up with a flat spot on each end so you need to add to the initial length of the pc. and trim after. Or you can roll, weld together, grind smooth and then roll again to get rid of flat spots.
          28" id will give you 28-1/2" od once rolled. 27-1/2" id will give you 28"od when rolled. This is using 1/4" dia rod of course.
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Lown 1/8x 36" power roller
          Arco roto-phase model M
          Vectrax 7x12 band saw
          Miller spectrum 875
          30a spoolgun w/wc-24
          RCCS-14
Name:	ti grill.jpg
            . Click image for larger version
Name:	Grill in bbq.jpg
            Odd shape so I traced the keg on plywood for a pattern.
            Used .218" diameter titanium rods for the grill.
              I think that grill will be around for awhile!
              Richard
                Show off...
                  Hi Ryan,
                  Are you still working on a cooler for your Helga?
                    I actually just picked up a heater core I am considering using for the radiator, not sure if it’s big enough. Had to sideline that project because I had a big smoker job I should’ve taken pictures of....weighed 4400 lbs when I was done. Fun job....have a teardrop camper job I’m on now, four weeks delay now waiting for the doors, and then rebuilding a big, old air compressor tank for the shop. So the short answer is yes.
                      Ryan,
                      Do you have a pump for this project yet?
                        Not yet.
                          Ryan I used a heater core from an old Chevy truck on a home made cooler way back. It worked great. That grill is awesome, not going to lose any hot dogs into the coals.
                            BH—that was very gracious of you. I ever make it up that way, I am taking you out for a beer....
                            OGD—I got my hands on a brand new heater core, but my fear is that it’s too small. Then I wonder, could I use a radiator big enough that I don’t need a reservoir, or would that be a bad idea?
                            I’m gonna build something awesome though...
                              Ryan,
                              Glad the pump arrived safely.
                              Good luck with your project.
