Here is a batch of parts I picked up from the machine shop. Some welding and assembly required. All 316 stainless. This is what you get for $4850. Started putting the pcs. together. To give some perspective on size the 16 square blocks on the right are 1.75" x 1.75" square.
Expensive parts
Expensive parts
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14Tags: None
Some sort of adjuster. Think cross feed on a lathe although they are not that. I'll post finish pics soon.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
Here is what they look like assembled. All total 4 pcs. The center block moves while the ends get bolted stationary. Slides on the two outer pipes and the center is threaded which moves the block.
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
