Loader bucket
  • Loader bucket
Name:	downsized_0502080815 (002).jpg
ID:	589883Click image for larger version
Name:	downsized_0508081829a (002).jpg
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    Here is a loader bucket that was in decent shape except it's worn thin. Had daylight showing in the corners. I cut out the sides and replaced with 3/8" plate, added pcs. to the side cutters, plated the floor on the inside and now I am welding on pcs. of a cutting edge to the cutting edge. It is supposed to have bolt on pcs. that go in between the teeth but the customer got a price of $600 dollars each or $4200 for seven of them. I found a new cutting edge for a machine they no longer have so I cut pcs. and will weld them on.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Miller spectrum 875
    RCCS-14
      All material is mild steel except the cutting edge pcs. It will only be used for moving material around a job site so it should last a long time. Over lapped the 3/8" plate onto the cutting as it was cracking at the seam of the floor to cutting edge. Someone before me welded the bolt on shanks to the edge already.
      Click image for larger version  Name:	downsized_0508081829b (002).jpg Views:	2 Size:	25.5 KB ID:	589888Click image for larger version  Name:	downsized_0508081829 (002).jpg Views:	1 Size:	23.7 KB ID:	589889
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
        Click image for larger version  Name:	downsized_0508081930 (002).jpg Views:	1 Size:	20.9 KB ID:	589891Click image for larger version  Name:	downsized_0508081929 (002).jpg Views:	1 Size:	23.8 KB ID:	589892
        I was originally going to weld the edge pcs. on the top side but once I started tacking them on it didn't look right so on the bottom they will go.
        MM250
        Trailblazer 250g
        22a feeder
        Lincoln ac/dc 225
        MM200 black face
        Miller spectrum 875
        RCCS-14
          Do you have to do anything special to those wear plate before you weld them on? Do you know what the material is?
            I just weld them. Never had an issue. If it's in the winter I just warm them up some to take the moisture out. For this I'm using esab 7100 1/16" wire which is what the customer has. If I was doing it outside I would use Hobart 21b. The edge was for a Cat D6 bolt on.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Miller spectrum 875
            RCCS-14
              Nice job! those holes cut on the inside wear plate of the floor did you plug weld those ?
              looks like A Deere John bucket
                Nice job on the segments. I usually use ar 400 for everything including the segments just because I don't want to see a bucket come back.
                  Yes plug welded the 3/8" plate to the floor. The inside isn't to bad as you can porta power everything tight. Here is the bottom done. Added a couple plates also. Click image for larger version  Name:	downsized_0510080920 (002).jpg Views:	1 Size:	23.4 KB ID:	589914Click image for larger version  Name:	downsized_0510080921 (002).jpg Views:	1 Size:	28.2 KB ID:	589915
                  MM250
                  Trailblazer 250g
                  22a feeder
                  Lincoln ac/dc 225
                  MM200 black face
                  Miller spectrum 875
                  RCCS-14
                    You do good work amigo.
