Make-up and Exhaust for a High Efficiency Furnace
  • ryanjones2150
    Ah...the pretty one...
  • Don52
    Originally posted by ryanjones2150 View Post
    Body doubles. Will the real Don52 please stand up?
    I am the one putting primer and gluing the PVC pipe.
  • Don52
    Originally posted by Goodhand View Post
    I think I see two or three different guys, working on your project. Can you explain?
    I have a bunch a practical friends, and we help each other out. We sort of trade hours. I do what I like for them, such as machining and welding.
    -Don
  • FusionKing
    Nice work
    You're hired. I have several projects waiting for you to start.
  • ryanjones2150
  • Goodhand
  • esracerx46
    Put a high efficiency unit when I built my own house 2 years ago. They do such a god job the exhaust gas is moist...but not really warm. Its common to see a giant glacier hanging from the side of the house.
  • MAC702
    Originally posted by Don52 View Post
    ...An 80% efficient furnace is a simpler solution for a garage because you don't have to deal with the condensate.
    Good point, but everything installed around here is a combination with an air conditioner, so we've got the condensate to deal with anyway.
  • Don52
    Originally posted by Ltbadd View Post
    Looks good Don
    Originally posted by MAC702 View Post
    Very nice. No one around here installs the high-efficiency machines, so I'm still doing everything with B venting.
  • MAC702
  • Ltbadd
    Looks good Don
  • Don52
    The last step was to install the bezel on the outside of the garage addition.
    12. Bezel installed
    13. Close up of Bezel
Name:	12. Bezel installed.jpg
ID:	588135Click image for larger version
Name:	13. Close up of Bezel.jpg
  • Don52
    The next step was to install the PVC piping and the newly fabricated Unistrut support.
    7. Installing the PVC Pipe
    8. Installing the Unistrut Brace
    9. Close up of Unistrut Brace.
    10. Bottom of brace
    11. Top of brace
Name:	7. Installing the PVC Pipe.jpg
Name:	8. Installing the Unistrut Brace.jpg
ID:	588129Click image for larger version
Name:	9. Close up of Unistrut Brace..jpg
ID:	588130Click image for larger version
Name:	10. Bottom of brace.jpg
ID:	588131Click image for larger version
Name:	11. Top of brace.jpg
  • Don52
    The next step was to fabricate a brace to support the PVC pipes. First I dipped the end of the Unistrut into a container of Hydrochloric acid (Muriatic acid from Home Depot). The acid does a nice job of removing the zinc so you don't generate fumes when you weld it. Next I welded the base to the Unistrut using a Lincoln 210 MP welder.
    4. Removing Zinc with acid
    5. Welding the base plate.
    6. Base plate welded
Name:	4. Removing Zinc with acid.jpg
ID:	588125Click image for larger version
Name:	5. Welding the base plate.jpg
ID:	588126Click image for larger version
Name:	6. Base plate welded.jpg
  • Don52
    started a topic Make-up and Exhaust for a High Efficiency Furnace
Name:	1. Box brake bending Aluminum sheet.jpg
ID:	588121Click image for larger version
Name:	2. Wrapped Plywood.jpg
ID:	588122Click image for larger version
Name:	3. Wrapped plywood installed in siding.jpg
    Last weekend's project is to connect the make-up and exhaust PVC lines to my high efficiency furnace for my garage addition. The first step was to bend a piece of Aluminum to wrap a piece of 3/4" plywood. The wrapped plywood was installed in the Vinyl siding to give me a good mounting surface for the exhaust bezel.
    2. Wrapped plywood
