Make-up and Exhaust for a High Efficiency Furnace
  • Make-up and Exhaust for a High Efficiency Furnace
Name:	1. Box brake bending Aluminum sheet.jpg
ID:	588121Click image for larger version
Name:	2. Wrapped Plywood.jpg
ID:	588122Click image for larger version
Name:	3. Wrapped plywood installed in siding.jpg
    Last weekend's project is to connect the make-up and exhaust PVC lines to my high efficiency furnace for my garage addition. The first step was to bend a piece of Aluminum to wrap a piece of 3/4" plywood. The wrapped plywood was installed in the Vinyl siding to give me a good mounting surface for the exhaust bezel.
    2. Wrapped plywood
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    The next step was to fabricate a brace to support the PVC pipes. First I dipped the end of the Unistrut into a container of Hydrochloric acid (Muriatic acid from Home Depot). The acid does a nice job of removing the zinc so you don't generate fumes when you weld it. Next I welded the base to the Unistrut using a Lincoln 210 MP welder.
    4. Removing Zinc with acid
    5. Welding the base plate.
    6. Base plate welded
Name:	4. Removing Zinc with acid.jpg
ID:	588125Click image for larger version
Name:	5. Welding the base plate.jpg
ID:	588126Click image for larger version
Name:	6. Base plate welded.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      The next step was to install the PVC piping and the newly fabricated Unistrut support.
      7. Installing the PVC Pipe
      8. Installing the Unistrut Brace
      9. Close up of Unistrut Brace.
      10. Bottom of brace
      11. Top of brace
Name:	7. Installing the PVC Pipe.jpg
Name:	8. Installing the Unistrut Brace.jpg
ID:	588129Click image for larger version
Name:	9. Close up of Unistrut Brace..jpg
ID:	588130Click image for larger version
Name:	10. Bottom of brace.jpg
ID:	588131Click image for larger version
Name:	11. Top of brace.jpg
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        The last step was to install the bezel on the outside of the garage addition.
        12. Bezel installed
        13. Close up of Bezel
Name:	12. Bezel installed.jpg
ID:	588135Click image for larger version
Name:	13. Close up of Bezel.jpg
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Looks good Don
          Richard
          West coast of Florida
            Very nice. No one around here installs the high-efficiency machines, so I'm still doing everything with B venting.
              Originally posted by Ltbadd View Post
              Looks good Don
              Thanks
              An 80% efficient furnace is a simpler solution for a garage because you don't have to deal with the condensate.
              Miller Thunderbolt
              Lincoln LE 31 MP
              Lincoln 210 MP
              16" DuAll Saw
              15" Drill Press
              20 Ton Arbor Press
              Bridgeport
                Originally posted by Don52 View Post
                ...An 80% efficient furnace is a simpler solution for a garage because you don't have to deal with the condensate.
                Good point, but everything installed around here is a combination with an air conditioner, so we've got the condensate to deal with anyway.
                  Put a high efficiency unit when I built my own house 2 years ago. They do such a god job the exhaust gas is moist...but not really warm. Its common to see a giant glacier hanging from the side of the house.
                    I think I see two or three different guys, working on your project. Can you explain?
                      Body doubles. Will the real Don52 please stand up?
                        Nice work
                        You're hired. I have several projects waiting for you to start.
                        Miller 30-A Spoolgun
                        Miller WC-115-A
                        Miller Spectrum 300
                          I have a bunch a practical friends, and we help each other out. We sort of trade hours. I do what I like for them, such as machining and welding.
                          -Don
                          Miller Thunderbolt
                          Lincoln LE 31 MP
                          Lincoln 210 MP
                          16" DuAll Saw
                          15" Drill Press
                          20 Ton Arbor Press
                          Bridgeport
                            I am the one putting primer and gluing the PVC pipe.
                            Miller Thunderbolt
                            Lincoln LE 31 MP
                            Lincoln 210 MP
                            16" DuAll Saw
                            15" Drill Press
                            20 Ton Arbor Press
                            Bridgeport
                              Ah...the pretty one...
