Welding table top
  • Gar
    I went with one inch. It’s in my Garage and measures 4ft x 3.5ft. It’s been a great table and I don’t have any regrets. I purchased the plate from a guy that worked in the building trade and had he some leftover cut-offs from a previous job. Do you need 1-inch plate? Probably not, but it’s been real nice having a flat heavy table now for the past five years.
    You can check out part-1 of the build here: https://youtu.be/6j6PFHc4ZPI
    Gar
  • ryanjones2150
    Slap a little Coleman stove up there and it'll be good to go. Cook some hotdogs while you're welding.
  • captain belly
    Wow.... it really does look like a grill chassis. now i'm never going to look at it the same again. HA!
  • ryanjones2150
    Looks like it used to be a gas grill chassis. Handy little mammer jammer.
  • captain belly
    Looks like my text didn't post with the pic
  • captain belly
  • FusionKing
    It's a handy size for us.
    We are currently planning to build one that I hope will be 3' x 30'
    That should cover our other "needs" we are planning
  • ryanjones2150
    I just gave a half sheet of 1/2" steel to a friend of mine to build a table that pretty much matches the description of yours there FK....he told me just this morning that it's just about perfect for his shop.
  • FusionKing
    I have a weld shop that does marine repair among other aluminum tig type repairs as well. I have a table with a top made from scrap steel approximately 4 ft. square and it is 3/8ths thick and has been great for about a decade.
    It is on medium castors and we roll it all over the shop which is about 6500 square ft.
    Every bit of it was free except for the Wilton vice that I mounted on a receiver for a trailer hitch.
  • ryanjones2150
    Yup...need to know how big you need it, what you're planning to build on it and your budget. You don't have to release your tax returns, just an example, "...I would like to stay under $500 in materials for this build..." Heavy casters will be expensive too, and don't try and cheap out on them or you'll be sad.
  • MAC702
    Every new post here lacks sufficient information and gets the same answer, it seems: "It depends."
    It especially depends on what you are building on top of it.
    Also depends on your budget, as many try to get as thick a top as they can afford, within reason, for their circumstances which may include needing to move it around or have room for clamp thicknesses. Size of the table will come into play as a smaller surface area can have a thicker top for the same budget and weight considerations.
  • Hosedragger622
    started a topic Welding table top
    Welding table top
    Needing to build a welding table and looking for recommendations on the table top thickness ? It will serve as a work bench also, it will also be on casters.
