Flush Mount I-beam
  • Flush Mount I-beam
    I am in the process of building an addition to the back of my garage to enlarge my shop area. The ceiling will require a 16 feet long W12"x16 lb/ft I-beam that will support the joists. The joists will support an attic, which will be used for storage. I chose to mount the I-beam flush with the joists to avoid infringing on the ceiling space in the shop. On the North side the I-beam will be supported by a wooden post. On the South side the I-beam will be supported by a 3" diameter schedule 40 Lally column, which will be located about 2 feet from the south wall of the addition to allow space for furnace ductwork between the Lally column and the south wall. The Lally column will rest on the 6" thick steel reinforced concrete slab. The column load will pass to a 2'x2'x2' pier, which is located under the slab.
    1. The crosshatched area in the first picture shows the floor plan for the new addition.
    2. The second picture is an isometric view which shows the new addition on the left side.
    3. The third picture shows using a magnetic base drill press to drill 9/16" holes in the I-beam for the 1/2" bolts that will fasten the 2x12's to the sides of the I-beam.
Name:	1. Plan view of addition.jpg
ID:	583708Click image for larger version
Name:	2. Isometric view of addion.PNG
ID:	583709Click image for larger version
Name:	3. magnetic base drill press.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    I welded a tab to the south end of the I-beam to attach it to the south wall to stabilize it during ******** of the I-beam, I used 0.035" wire with short circuit MIG because the plates were only 3/16". I used Lincoln 71M Outershield fluxcore to weld a 1/2" plate to the north end of the I-beam (330 in/min WFS @ 23 volts). In addition to stabilizing the I-beam, this plate also spreads the load out on the upper 2x6 wooden plate to reduce the compression stress on the wooden upper plate to acceptable levels. I also used 71M wire to weld a tap plate to the bottom of the I-beam to be used to attach the upper end of the Lally column.
    4a, 4b, & 4c Pictures of South tab
    5. North tab
    6. Tap plate welded to bottom of I-beam
Name:	4a. South tab.jpg
ID:	583712Click image for larger version
Name:	4b. South tab.jpg
ID:	583713Click image for larger version
Name:	4c. South tab installed.jpg
ID:	583714Click image for larger version
Name:	5. North plate installed.jpg
ID:	583715Click image for larger version
Name:	6. Tap plate welded to bottom.jpg
    Miller Thunderbolt
    Lincoln LE 31 MP
    Lincoln 210 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      I also used 71M wire to weld a plate to the top of the Lally column. Next I used a manual fork lift to erect the I-beam. The North end of the I--beam rested on the North wall. I temporarily supported the South end of the I-beam with an adjustable Lally column to level it.
      7. Plate welded to top of Lally column
      8a & 8b. Using manual fork lift to lift I-beam into position.
      9. Adjustable Lally column
Name:	7. Plate welded to top of Lally column.jpg
ID:	583718Click image for larger version
Name:	8a. Using manual fork lift.jpg
ID:	583719Click image for larger version
Name:	8b I-beam in position.jpg
ID:	583720Click image for larger version
Name:	9. Adjustable Lally column.jpg
      Miller Thunderbolt
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DuAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        I screwed the plate, which was welded to the top of the of the Lally column to the tap plate,which Click image for larger version
Name:	10. Plate welded to bottom of Lally column.jpg
ID:	583723Click image for larger version
Name:	11. Lally column mounted.jpg
ID:	583724Click image for larger version
Name:	12. Hanger brackets installed.jpg
ID:	583725Click image for larger version
Name:	13. Status of addition.jpg
ID:	583726was welded to the bottom of the I-beam and let it hang free. Next I attached a 1/2" plate to the concrete directly below the I-beam using Tapcon fasteners. Finally I TIG welded the new plate to the bottom of the Lally column. I had to TIG weld it because my 71M outer shield had absorbed moisture due to the high humidity so I was starting to get worm tracks in the weld. The last step is to use hanger brackets to attach the joists to the 2x12, which are bolted to the I-beam.
        Miller Thunderbolt
        Lincoln LE 31 MP
        Lincoln 210 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Heck ya man. I put in an ibeam across the width of my shop to support the loft for storage. 24' supported by two steel columns bolted to the floor. Working by myself so I had to get creative since the beam had to go up in three pieces and get welded in place. Then I put a low head room trolley on it and that has been the single best upgrade to my shop other than the ventilation fan. But you're way better at photo documenting this stuff than me.
          Nice work.
            Nice work, you could support a battle ship, I like.
