Core Drill Repair
  • Core Drill Repair
    My friend Bryan is a Civil Engineer.
    He uses the core drill to drill and extract soil samples.
    Unfortunately he often encounters rocks during the drilling process.
    In this case three things can happen:
    1. The auger ingests the rock
    2. The auger pushes the rock into the wall of the bore hole.
    3. The blade of the auger gets bent.
    The auger that Bryan dropped off was the third case.
    The following pictures show my process to repair it:
    1. Bend blade of core drill
    2. Arbor that I made
    3. Last little gap
    4. Weld position with arbor installed and gap closed
    5. Core drill repaired
Name:	1. Bend blade of core drill.jpg
Name:	2. Arbor that I made.jpg
Name:	3. Last little gap.jpg
Name:	4. Weld position with arbor installed and gap closed.jpg
Name:	5. Core drill repaired.jpg
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Nice work and great sequence pictures!
