Forgot one square check cost me a boat load of grief. I hate when a simple little check is over looked all good now.Ill post as it goes along.
Need another cart
When I put the 1" onto the main frame I did not check the square. Had to zip one side to bring back square. It might not have been to bad but I want to put two drawers on it with slides. And to have them turn out I better do all I can to keep it plum
The way our dollar is up here you could afford 2 30 packs. As far as the keystone im not so sure. The tri axis is nice but you can do a good bit with just the double. I had a set of home made ones I gave away to a young welder. You had to use clamps but it worked good. I just tapped out the plates for the front casters tonight. I like to go with a wheel set up on the back with a axle. If I get time I'll get on the brake and brake the drawers.
