how do i draw a straight line on the bowl end of a propane tank i need it straight so i can frame the hole with flat stock.
How do i do it?
Please actually use the subject line for the specific subject.
I had to think about your question for several minutes before assuming you are trying to duplicate the item in the picture, and want to draw and cut out the square for the door. Maybe I'm dense.
I would do it by rolling a straightedge along it as I drew the line with a pencil. If I slipped, I'd wipe it off and start over. You ain't making a piano. It'd be even easier if the cylinder was resting against a flat surface of the right height and the straightedge was long enough to always be flat on it on the side away from where it touched the cylinder.
If you secure the tank vertically, you can jig up a fence and use a metal-cutting circular saw with the depth at the right level to do most of your line, too.
What cutting processes do you have available?Last edited by MAC702; 01-16-2017, 02:55 PM.
Originally posted by Dr.dieseljr View Posthow do i draw a straight line on the bowl end of a propane tank i need it straight so i can frame the hole with flat stock.
You should always post a disclaimer
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Originally posted by aametalmaster View PostUse a string. Tape one end to the tank where you want it. Then pull the string to the other side and tape it. Then use soapstone, sharpie or whatever to mark the line. Simple...Bob
Originally posted by MAC702 View Post
Might be close enough, depending on the degree of curvature, but the shortest line between two points on a 3D curved surface will not be a straight line. This is why pilots and sailors use a Great Circle route instead of what we would think of as "straight" between two cities with similar latitudes.You mean it wasn't supposed to be LOL...Bob
