My customer was replacing the front wheel bearings on his Suburban. The bolts that retained the flange for the wheel bearing to the knuckle were frozen. His helper rounded the head of three of the bolts. I cleaned up the top of the bolts with a Carbide burr using Foredom flex shaft grinder and some Acetone. MIG wouldn’t work because the hole in the hub was too small for the MIG nozzle. I could have stick welded it but I wanted to camp out on top of the head of the bolt to really heat it up, so I used TIG instead. I used a conventional TIG nozzle to fit through the small access hole in the hub to gain access to the top of the bolts. One bolt was so badly rounded that I had to weld a nut on the top.
Using Welder to Remove Stubborn Bolts
Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
BridgeportTags: None
The other two were slightly rounded so I just heated the bolts by welding a dome on the top of the hex head of the bolt. I used a little Kroil and the bolts came right out. Welding is a nice way to remove a stubborn bolt.Miller Thunderbolt
Lincoln LE 31 MP
Lincoln 210 MP
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
Not bad. I have heard of this method but never tried it, definetley saving it for the future.
I did have to repair a cast steel or cast iron roof drain once. It was leaking around the flange and would drip into the office below it.
So i went up with my trusty old drill, some bits, a tap and some bolts. Drilled the hole out a bit, threaded it to a 5/16" X 18 bolt, WELL. I got a bit ahead of myself and tried using the drill to tap faster... What a mistake that was.
tap broke inside, to remove the flange would be destroying that section of the roof so later that day, brought my tig up there, cut out the hole and removed the tap, then put the pieces I cut out back in and welded it back up. It worked
Amazing what welding can do.if there's a welder, there's a way
I run into this all the time. Every plow truck I work on this happens to me. Without fail. I just put a little heat on the knuckle and flange, then use a Williams/Snap-On TurboSocket and they come right out. Those sockets are, without a doubt, one of the best tools you can own. There big time savers.
FWIW..... a MIG bead on the inside of a stubborn stuck wheel bearing race will usually shrink them enough to pop right out........
Originally posted by H80N View PostFWIW..... a MIG bead on the inside of a stubborn stuck wheel bearing race will usually shrink them enough to pop right out.......
Originally posted by Tinker Joe 2 View PostDid about 50 of them here while back on the rollers, under the rails on a JD 450 Dozer, then had the rails blasted and went back together, that was a job, sure glad to have an impact.
Lostone, that is a big bearing and race, that is some big machines you all pay with.
2 Photos
