I also think it was 1/16 welding rod not 3/32.
Friendly Welding Challenge
So def need to get some smaller filler... Currently running 3/32 filler and tungsten and not working, blowing through the can before the filler will get hot enough to melt.... Need to pick up some smaller filler and tungsten....-Jimmy
Syncrowave 200
Millermatic 211
Hypertherm Powermax 45
Originally posted by Oldgrandad View PostBack in the early 90's talking smack with my boss about how I could weld anything he bet me I couldn't weld a beer can. I told him noooo problem. His favorite beers were Bud Lite and Michelob. So I went out bought a six pack of each drank one of each cut the cans in half and attempted to put them back together. The first ones were not pretty but by the end of the first 12 beers I was feeling good and the welds were starting to look like welds. I finally managed to get one welded all the way around. poked a hole in the bottom filled it with water and sealed the hole. I had a full can of Michelob/Bub Lite. I've seen a guy lay a bead on the side of a coke can but never seen anyone else weld two halves back together. That's the challenge. Any takers? I'd love to see your pic's. I have one of my practice cans it's not pretty but it's welded I'll post that pic. To held you all out the machine was a syncrowave 350 set at 4 amps with the arc balance at 90% penetration. I used 4043 welding rod 3/32 dia. and put all the heat on the rod melting it into the can. Good Luck, hope to see pics soon. [ATTACH=CONFIG]n571320[/ATTACH] [ATTACH=CONFIG]n571321[/ATTACH]
