Our lift at work had a bad spindle and the boss said take some measurements and have one made. So I did, and I made it and rebushed the hub. The shop fitter cut the old one off and welded mine on. All better now...Bob
Spindle repair.
Bob,
I have never seen the drill attachment with bearings for the cross slide of the lathe.
•Was this a standard attachment or did you make it?
Attached is a picture of drilling a hole with a standard QD tool holder which accommodates Morse taper tools.
I use this in place of the tail stock drill Chuck, when I am drilling a hole in a small shaft and I want it centered perfectly.
•What caused the shaft for the lift to get damaged?
DonAttached FilesLast edited by Don52; 06-19-2016, 08:49 AM.Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
- 1 like
Don. I invented the cross slide hole driller to make furnace nozzles for a place I used to work. They had holes that were angled and had to be at all different degrees. I use a protractor dial on the spindle end to do the degrees. I am going to start selling them at least in my mind.
The lift shaft was just from years of no grease and metal on metal. A local "professional" said that spindle would last another 100 years. I saw it drive by and said that's not right seeing the wheel leaning 10 degrees out at the top. So I took it off and found all the damage. It prob was purchased damaged and the professional was a real salesman and didn't have a clue. I am doing the other side now but it wasn't as bad. I did rework my shaft drilling it from the back and adding some grease holes and a fitting...Bob
