Seeing the MIG Joint When it is Under the Nozzle
  • ryanjones2150
    Oh man! You put me on the spot here...they're kind of shy around strangers ya know...
  • old jupiter
    Originally posted by gnewby
    Our Nomex is very light weight and even if is FR material I am afraid it would get very hot on the neck if any welding sparks landed on it.
    Never had mine catch fire, though it has some tiny black marks. I suppose if you were welding overhead and a big blob of metal fell out of the joint you could set the cape on fire. . . but my early experiences of those falling blobs was that they fell into my boot laces, not down the back of my neck.
    In the middle of last summer, during record-hot days for this area, I was welding up a big frame for construction work, joining pieces of 12-inch I-beam. To have the frame come out acceptably flat, we laid out the pieces on a big hunk of 1 1/4" trench-plate. By late morning, all of this big steel was egg-frying hot. I was in full leathers, lying stretched-out on my belly on the trench-plate in the middle of the I-beam structure, my arms stretched out in front of me, running vertical-up welds in some tight corners. I did have a layer of cardboard between my bod and the trench-plate, but still the big vision problem was the sweat that was POURING off of my forehead. One of the few slight sources of relief came from pre-wetting down both my shirt and my little helmet cape, with the water evaporating out and cooling things a little.
    You did say yours was old Nomex, and I don't know how age and usage might degrade the fire-resisting qualities . . .
    (EDIT) Post links to your photos of scantily-clad cheerleaders, Ryan.
  • ryanjones2150
    Welding something to your table...ha! And I've never accidentally cut into mine either...we might need babysitters in our shops...scantily clad cheerleader types would do.
  • gnewby
    Thanks Jupiter, I will have tor remember that as we have all kind of old Nomex from work that are pretty much wore out. We also have several Bullwark pants that are always needing to be replaced that might make a good cape for the welding helmet. Our Nomex is very light weight and even if is FR material I am afraid it would get very hot on the neck if any welding sparks landed on it. The Bullwark material from the old jeans would probably be better as long as all the FR has not been washed out of them. The FR hood I have is cotton lined which will probably be very hot to work under when it is warmer but for now will give me a good idea as to how the cape will work.
  • old jupiter
    Originally posted by Don52
    Old Jupiter could jump in with his experience, but I would use treated cotton like from an old welding jacket. I would attach it with Velcro. Don
    Old Jupiter can always jump in with . . . something to illustrate how NOT to do things. This morning I had some pieces of steel angle clamped to the welding table out in the Zeppelin Hanger to be welded together. A darkish day, too little light, and me too lazy to set up a light-stand. Can you see what's coming? Right, after making a bunch of one inch welds to get the structure stabilized for all-around welding, I raised my hood . . . and found that I had welded the bottom edge of one piece TO the welding table!!
    Of course, this had to be a good weld, with good 6011 penetration, and it had to be in a right angle corner, inaccessible to a side-grinder. Oh, I finally dealt with it, but MUST I do these things??!!!
    Anyway, the helmet cape. Mine is homemade, using a piece of fire-resistant Nomex I happened to have. It drapes very loosely over the back of my head just enough to keep the back-lighting out. The one shown in the Amazon link looks great for keeping hot bits from burning your neck, but it also looks uncomfortably hot for a warm day, and my hot breath might fog my lens on a cold day.
    Hey, MY little Nomex cape is bright orange, OSHA would love it.
    (EDIT) Here's some. It says "6 oz." I don't know if that's heavy or lightweight cloth; mine is light, which is what I want. https://www.pegasusautoracing.com/pr...FQeraQodIMMOBQ
  • MMW
    I have always used glass shaded lens. It does make a big difference. I sandwich it between two plastic clears that I change as needed. Another thing to try is a cheater/magnifier lens. Once I used them I won't go back. I bought a few different strengths & use them always now. I just put it in place of my inner clear lens. As you get older these help a lot.
  • gnewby
    Thanks Don I think what I have will work okay.
  • Don52
    Here is a link to a store bought cape:
    http://www.amazon.com/gp/aw/d/B003L1...=welding+hoods
    Don
  • gnewby
    Don
    I ended up asking the wife yesterday if she had any velcro which she did have, so I told her what I had in mind and she told me to bring in my welding helmet and she would see what she could do. I went and grabbed all three welding helmets I have and brought them all in plus an old FR winter hard hat liner. She fixed up all three of the welding helmets so that the old winter liner worked in all three of them. Good Valentines gift for me yeah!
    I also replaced the cover lens in all three helmets. The helmet I use the most is my miller auto darkening it has a 2.50 cheater lens in it. Next I have
    an old auto darkening KT helmet it does not have any cheater lens and do not know if one would work in it unless it is just held in with tape. the third helmet I have has a gold lens, shade 10 with a 1.75 cheater in it.
    So far I have not tried any of them since changing the lens and getting the cape fixed up for them. Hopefully will be able to soon. I would like to get another of the 2.50 cheater lens for the fixed shade hood and try it to see how well it will work so I don't have to be switching it from hood to hood.
  • Don52
    Phil posted a link to a video for the Jackson TrueSight II helmet on the Hobart weldtalk forum.
    I thought that the video was great for defining the four different aspects that make up Optical Clarity:
    1. Optical Quality - Straight lines appear twisted.
    2. Light Scattering - Point light source looks diffused.
    3. Homogeneity - Uniform color across the entire viewing area.
    4. Angular Dependence - See clearly in the center of the lens and off center.
    Below is a quote from my first post.
    1. Using a lighter shade
    I use a manual hood with a #9 shade lens that is gold plated to reflect some of the arc light and this works very well. I tried a #8 lens and I found that although I could see under the nozzle better, the arc was too bright and distracted me.
    The gold #8 lens that I used for this test was made by Weldmark part number 814508. For my test I used a brand new plastic cover plate on both the inside and outside of the lens. Based on the Optical Clarity definition from the video, I can now say that the problem that I had was that the lens caused the light source to appear diffused instead of a point source. The diffused light washed out the joint that I was trying to see. In the mean time I purchased a second #8 lens manufactured by Harris part number HAR1034508. This lens was perfect. With the new lens the light appeared as a point source and I found it really easy to see the joint. I have attached two pictures from the video. The "bad" one was exactly the problem that I had with the Weldmark lens. The "good" one was how I could see the joint when the light from the arc didn't wash it out. For my old eyes the arc wasn't too bright; It was comfortable.
    Don
  • Don52
    Originally posted by gnewby View Post
    Is there any recommended suggestions as what to use for the cape and methods of attachment to the hood etc?
    Don
  • gnewby
    I'll have to try the cape when welding outdoors.
  • ryanjones2150
    What helps me, especially when doing a lot of mig welds...I set my hood to a lower then normal setting and wear sunglasses under it. The sun glasses don't seem to add much, but it's just enough that I don't end up with a big blue spot in the middle of my vision and yet I can take advantage of the lower shade setting.
  • Don52
    Originally posted by old jupiter View Post
    One thing you didn't mention in your list is a helmet-cape (or whatever they're called) to keep light out of the inside of the helmet. This is a must-have for me for outdoor work, and even helps against indoor back-lighting.
  • old jupiter
    Good, Don, you speak to a problem a lot of us old goats have, seeing what the heck we are doing!! All too many times I have been capping a butt joint and lifted the hood to find out that my bead has wandered out of the joint and off across the plate. I don't even try to finish off a project by "writing" script (the customer's company name, for instance) anymore. Making a neat hardfacing anti-wear pattern of beads is nearly beyond me now.
    I had never heard of that MIG-Light gizmo until your post, and I have to get one, great tip!
    I concur with all you said, except maybe the welding in sunlight, which for me seems to hurt as much as help. One thing you didn't mention in your list is a helmet-cape (or whatever they're called) to keep light out of the inside of the helmet. This is a must-have for me for outdoor work, and even helps against indoor back-lighting.
    Good post.
