Read in a post that their is a chemical sharpening agent for electrodes. I have always ground my electrodes, but I would like to learn more about different ways in getting the point on TIG electrodes.
Tig electrodes sharpening.
What a great idea!
Please keep us posted on whatyou find. And I'll look around and do the same.
ThanksTriggerman
Ammonia refrigeration tech
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
Here is some of the stuff I found regarding Chemical sharpening
Chemical Tungsten Sharpener
Chemical Sharpener For Tungsten Points, Over 500 Perfect Sharpenings, Without Grinding, Without Leaving Work Area, & Without Contaminating Tungsten.
Select 5 Oz Refill, or 5 Oz Refill w/ Holder Kit.
Enlarge/Details
Category -> TIG Torches Tungsten Etc. -> N1 Tig Tungsten + Sharpening
Item Tried to get the picture to some over, but no go.
The chemical sharpener can be bought at weldingsupply.com for $8.28 (5 oz)Miller Dialarc HF
Millermatic 180
Warner Swasey #3
Burr King Grinders
I've used it, several years ago. It works almost as good as grinding, & nearly as fast. So now I just grind mine.
The chem-sharp is kinda fun though, just get the tungsten hot, (either by shorting it for a few seconds at full amperage, or by heating it with a torch) then dip it in the "magic powder" move it around a little bit, pull it out & you've got a point on your tungsten!
If you've never seen it work, spend 10 bucks or so & play with it some, but I'll bet you'll go back to grinding your tungsten.
HTHProfessional Auto Mechanic since 1974
My own shop since 1981
Cya Frank
What about the Techsouth Powerpoint Tungsten grinder. Looks alot like a dremel tool with a customized head to accept different size tungsten. It has good reviews but the cost is over $200.00. Anyone used one of these...
Their is also another item that looks just like the above described sharpener called the Sharpie same price range.Last edited by gearhead; 11-24-2006, 06:24 PM.Miller Dialarc HF
Millermatic 180
Warner Swasey #3
Burr King Grinders
Originally posted by gearhead View PostWhat about the Techsouth Powerpoint Tungsten grinder. Looks alot like a dremel tool with a customized head to accept different size tungsten. It has good reviews but the cost is over $200.00. Anyone used one of these...
Their is also another item that looks just like the above described sharpener called the Sharpie same price range.Regards, George
