Dynasty 200 DX noise at idle
  • Dynasty 200 DX noise at idle
    New to the site and new aspiring weldor. Taking tig classes at the local c.c.. Just purchased my new Dynasty 200 DX and love it, however, is it typical for this machine to make noise at idle or when machine is on but not in use? It sounds similar to a refrigerator running, or overhead power lines, or maybe a ballaster from a flourescent shop light. The machine works great but just want to be sure that it does make noise when on and not in use. -- Don't want to be stuck with a $3000 defect.
    Thanks
    I don't own one but I've read LOTS of comments about the noises the Dynasty series makes.
    Yours sounds normal (or maybe quieter than most!)
    Some of the guys describe theirs as "R2D2" because of the hum, squeals, chirps, & other noises!
    HTH
    My own shop since 1981
    Cya Frank
      Thanks
      Mine does the same thing, it is normal and would be the Auto-Line at work. If you want, change the amperage and listen to the hum change pitch while you do it.
      Regards, George
        The burbling noise was normal on the 200DX. My 300DX does not make a sound when at idle though.
        T.J.
        Miller Dynasty 300DX
        HTP MIG 240
        HTP 380 Plasma
        Bridgeport Milling Machine
        South Bend Lathe
        Etc. Etc....
        tjsperformance.com
