Lincoln/ Miller?
Just have some questions, since i know nothing about oil field work or pipe line welding. All I have worked on has been equipment repair/fabricating. Why will the Bobcats not hold up. We have 6 Bobcat 250s. 5 are diesel and 1 gas. We weld 1/8" 7018 all the time with them. We usually dont weld all day like a pipe line welder would but we've had no trouble with them. The newest welder we bought is the Big BLue air pac. What a welder. ght it mostly for the built in air compressor. Not allowed because of their AC ability. All we ever use is DC. Is that what they require, if so as you know the bobcat has both. As far as the few welding specs I've seen I've never seen them dicatate which welder you had to use, only what Type of weld, process to use,filler metal etc. Just curious?
times may be a' changin'
True, the gray machines are still the machine "of choice" for most pipeline projects. However, Miller's PipePro 304 is breaking down barriers in this field. Now there are specific drilling outfits/pipeline companies that won't allow blue machines on the job, but I'm skeptical (not positive) that the specs call for Lincoln equipment. According to my pipeline contacts, the machines getting kicked off projects are only the Bobcats and some Trailblazers. They're not allowed by the contracting company because of their AC stick capability....the company does not want to risk someone doing root passes with a sine-wave, which can increase the chance of undercutting leading to cracks and can impact weld metal dilution. Basically, the company doesn't want to pay for reworks that result from the above. Not an issue with the PipePro since it's DC only and does (according to guys in the field) a great job on root welds with red or gray rods. As far as the Bobcat not being able to hold up in the field, I'd say possible but not likely since the 250 series can easily handle the load required to burn 1/8" & 5/32" E6010 and E7018 pipilines use most. I certainly think that as the PipPro's notoriety grows, more pipelines will allow guys to use them.
That's what I'm hearing from the guys in the oil patch...and it's blowing up here in parts of Colorado and Wyoming.
Well......that's the way it is.
Or, so I've heard. The reason I'm hearing is because a Lincoln poopliner will weld every day, all day and never give up. (propaganda) Guys have tried to go out there with Bobcats and burn them up trying to keep up. Mostly IMNSHO it is just prejudice. Be that as it may, that's the requirement.
Lincoln/ Miller?
Hey all,
Just wanted to start a poop storm! The oilfield is going gangbusters in North Texas an there is lots of welding work available right now. The word on the street is that Millers aren't being allowed on most of the jobs. Most of the guys that I've talked w/ are pipeliners and fabbers of oil rigs. They go and test with their Millers and pass and then are told in order to work they have to have a Lincoln. The rumor on the pipeline is that Miller won't meet "the Specs". I have been told that Lincoln wrote the specs and that is why the Blue Stuff won't do. The irritating part is the static that guys catch from otheer welders over the color of their machine. Just wanted to throw it out there and see if yall had any say on the subject. Also if there is a Miller rep that wants to enlighten us on specs and techs, join in!
JWOODTags: None
