Alumalloy
  • Alumalloy
    I saw one of those infomocerials yesterday and they were trying to sell Allumalloy, an aluminun "welding" rod that you can use a propane torch to do the work.
    Anyone ever try this stuff?
    Jerry
    I have some from Crown Alloys that is about the same stuff, but i have never needed it...Bob
      I have some from HTS ( I think thats who makes it?) , it works with propane on very thin stuff,mapp works better and oxy/acct for thicker material. If your welding aluminum cans I swear by it, but the need for custom mountain dew tall boys around here is thin. I did give a rod to a local auto guy and he managed to repair a ear on a water pump housing with it. I can say it works but as far as how much you will use it depends on if you have a tig welder or not, if you do you probably wont use the stuff much. Plus it is a bit $$$ ! The thing that I liked was that you could plug a hole with it on really thin stuff, thought it would be great for aluminum boats.
        Its been around and sold by one company or another for several years that I know of. I first saw it back in the 80's.
        Nobody hardly uses it though. I think it works sort of like soldering together a Copper water pipe & fitting does instead of a true weld since the parent material and the filler never melts and 'flows together' the way it does in a weld.
        If that's how it works, it can never bond the pieces together the way welding does, and you wouldn't have as strong of a joint if the parent material is harder or more flexible than the filler material.
        I can see a market for it, and lots of uses in low pressure/low stress type applications-- Alum. hull boat leaks is one, but for some reason, the stuff never really got popular. I'd guess that for what most people would do with it, JB Weld or some sort of Epoxy compound will work just as well.
        "Gone are the days of wooden ships, and Iron men.
        I doubt we'll see either of their likes again".
        Circa 1920.
        Author:
        Unknown US Coast Guard unit Commander.
          Alumalloy
          I found a box of flux cored 1/8" aluminum filler rods for gas welding at work. I had never thought of gas welding aluminum until recently when MIG and TIG weren't available. I tried using the flux cored rods and they worked pretty good. I fixed two cast air intake pipes, about 1/4" thick through the cross section, and the repair worked quite well. I dont know what brand of rods these are, but they definately melt into the base metal and leave a color matched finish. I also used these rods for repairing a broken cast brake drum dust cover from an ATV. They didn't work as well for the cover, but it's holding still, after a few months of rigorous use. I still prefere TIG, but the gas rods seem to work well in a pinch.
          Jonny
          Dynasty 300DX
          Esab PCM 1000
            Harbor Freight sells it.
            I have bought some at Harbor freight. HB sells it in a tube with about 8 or ten sticks for about $10.00.
            I just wanted to check it out. Like every one has said it's fine for thin stuff but very pricey.
            This is my first post but a long time reader.
            David
            Learn new things every day.
            You only have so many days.
            Century Mig.
            Craftsman stick.
            Miller Diversion 165 Tig
            Hobart Plasma
            HF DC Tig
            1-O/A out fit
              Hello David and good to see you posting.
                I would also agree that its more of a bonding agent verses welding.
                I have never used it but have seen it used at shows, I would think it would be great for a hole in an aluminum row boat.
                They used to use it at the swap meets showing how you can weld pop cans along with repairing Ford escort heads back in the 80s.
                I have a sneaking suspition that it wouldnt be good for aluminum heads.
                  If the filler melts below 840F, and joins metal through bonding by capillary action, then it is soldering. If it melted above 840F, but below the melting point of the object being joined, then it would be called brazing. This stuff is solder.
                    Information for safety wear
                    Jerry
                    Sir,I want to know the price of that apron and gloves which you puted on for your protection.Also want to know from where you buy these.
                      I would not even call it that good! Its just zinc based "pot" metal. Real brazing and soldering materials are aluminum/silicon based, with some of the real solf solders having lead and tin as well. This stuff has no ductility, and in fact can cause the base metal to become brittle depending on the alloy.
                      Miller Dynasty 300DX
                      Miller Dynasty 200DX
                      Miller Spectrum 375 extreme
                      Miller Millermatic Passport
                      Miller Spot Welder
                      Motor-Guard stud welder
                        Zinc is brittle, Zinc also oxidizes easily (Think about it - what are sacrificial anodes made from?). Brittleness and corrosion susceptibility aren't desirable in any repair. It's a cruel joke on the consumer when they market this stuff as acceptable for repairing small aluminum boats.
                        If a piece is impossible to fix by welding or "real" brazing, I'd resort to epoxy before using that stuff.
                        2007 Miller Dynasty 200 DX
                        2005 Miller Passport 180
                          Actually we are going away from zinc, some of our anodes are aluminum alloy, some are now magnesium.
                          Miller Spot Welder
