Thanks to TomV. I am trying out the link in your post right now. It works good.
Amos F
Tons of dross with my new Spectrum 375
Spell Checker
Originally posted by Amos F. View PostD**m I wish I could could see my spelling mistakes before I post something. Is there a spellcheck on the post page?
I ran 1 1/2 black pipe all the way around my shop, so it makes a loop and then tee'd in the supply from the compressor tank. I used 1" drops where I wanted a manifold.
I run a 1" impact with a really big manifold off two separate places in my shop. The impact has 30' of 3/4 air hose plumbed permanently to it with the male manifold coupler on the other end. I have had trouble with it breaking off 1" wheel studs (diameter not swrench size) when really hitting them hard.
thanks for the links to the spell check sites. I will go looking there. I am not very computer literate, and seem a real slow learner with this thing.
Amos
Originally posted by harcosparky View PostA Little Update ....
OK so we all know a cool dry air supply is important, and so is FLOW.
I have a 80 gallon compressor very capable of providing what the 375 demands and was feeding it throug 25 feet of 3/8" hose and I was satisfied with the results. Well I was curious and decoded to up the hose to 1/2".
Did it make a difference? I'll say it did.
The amount of dross I saw on some 1/4" angle was nothing compared with the 1/2" line as compared to the 3/8" line, and I wasn't really trying to get a great cut .... just a quick cut across the angle.
I set the compressor output to 90 PSI and adjusted the regulator on the 375 to the upper limit.
It DEFINITELY made the difference for me.
Get Firefox for your browser (it's free!!)...it has spell check built in so it will work on any web page you type on. SSS
http://www.mozilla.com/en-US/firefox/
Originally posted by Amos F. View PostEver notice how your impact works better with a half inch line than a 3/8? Its all volume supply.
Amos
Sadly for me the 375 will be installed about 40 feet from the compressor, so we are gonna hard plumb air to it with pipe. Another expense, but it will cut back on the aggravation level. Probably run 1 1/2" pipe, using 4 feet of 1/2 between compressor and pipe and then between pipe and plasma cutter. If I have to I will fashion some sort of air resovoir at the plasma cutter end.
It works great for me!
I also always use the "preview post" button & read it as it will appear, before posting
vtwin4life,
I teach high school metals classes and I have to say that your cuts look similar to what I see coming from my students the first couple of times they try it. Just keep working at it and you should see better results. It almost looks to me like your travel speed was a little fast. That actually is the biggest problem I have with my students, getting them to slow down and let the machine do the work. Either too high or too low a travel speed can cause dross to form.There is usually a range of travel speed that will produce dross free or minimal dross cuts. That range is something you will have to find while playing around with the machine.
Good Luck,
BrennenLast edited by unib63; 12-15-2006, 10:31 AM.
Originally posted by Amos F. View PostD**m I wish I could could see my spelling mistakes before I post something. Is there a spellcheck on the post page?I use it a lot!
Funny thing happened to me yesterday. I have read thius post since the very beginning and had almost forgot about it. I have a Hypotherm 1000 I bought used and have been happy with it but I always thought it should leave less dross (sound familiar?). Any how I built a bracket to mount it on my shop wall and ran it with a 25 foot flexable air line for the last year or better. Yesterday I plumbed in a new drop tube from my permanent air line so I only have about 2 feet of flexable air line running to it.
Guess what, almost all the dross is gone. I believe that I had too much resistance in the air line that I was using. It is the only explanation I can see as I didn't even change the filter (motorcraft) when I hooked up the new air line to it. Just another one of those hard to believe things in life. Ever notice how your impact works better with a half inch line than a 3/8? Its all volume supply.
Amos
Air Compressor
I've read this thread with much interest and since you're pretty much at your "wits end" with this machine might I suggest hooking the machine up to a higher volume air source -- just to test it out.
I'm not trying to be "a pain", but I had the same problem with my cheap import Homier Speedway cutter. It wouldn't cut worth a darn when hooked up to my old 1980's vintage Sears 2HP 20 gal compressor (5.6 CFM @ 90 PSI). Same problems that you're experiencing. I asked around and everyone said that the compressor was adequate. Hence, it must be a problem with the cutter. This went on for weeks.
Then my friend wanted to use it for one of his projects. I went to his house and hooked it up to his Home Depot 60 gal Husky (10.2 CFM @ 90 PSI) and guess what? The darn think worked like a charm -- no dross, just nice clean even cuts all day long.
Since then I purchased a PUMA 5HP 60 gal compressor and my problem is solved.
Just a thought -- I have no experience with the Miller cutter, but knowing the company's customer service model, I would assume that they wouldn't just ship you a replacement machine that wasn't adequately tested before it went out the door.Last edited by rasommer; 11-27-2006, 10:28 AM.
Originally posted by vtwin4life View PostNo offense taken. I hear what you are saying. I would just assume my inexperience with the tool would come into play more towards the spec'd limits of the machine. At 1/8" and full power, I would think even a child could make a decent cut without diagonal cut lines and heavy dross on the underside of the cut? No?
Dross is of course the material cut away by the torch. It has to go somewhere, if there is enough pressure and flow hopefully it will be blown down and away assuming there is clear space beneath for it to fall.
Diagonal cut lines in the kerf indicate the need to change one of two things, maybe both. 1) Torch speed -OR- 2) Torch angle
I at times get diag lines as well though not as often as when I first bought the unit. Keep in mind I am not using a " drag tip " though I do at time drag the tip on the metal being cut.
By far the best cuts have been with a standoff as recommended by Millier. Making sure the torch is held so that the tip points STRAIGHT DOWN and I move the troch in a deliberate and constant speed.
The other poster is right. This is a new tool and it will take some practice to learn what it can and cannot do.
Like I said, I get great cuts and I get bad cuts. The good cuts are increasing in frequency with practice. Dross for me is at times a part of the process. I have had no Dross that could not be removed with a slight tap.
Tomorrow if I have time I will show some pics of cuts made in some angle iron. it is either 3/16" or 1/4". I will also do some sheet metal cuts as well.
Give it time and practice. It's not the 375 that is at issue here, I think you'd see the same thing with any plasma cutter the first time out.
