Ebay Item # 230046967036 is a new Millermatic 175 mig welder for $679.95 with free shipping and no tax. 7 left to sell. I have no connection to the seller. I just bought one.
MM 180 is apparently MM 175 + 5 amps + $100. Not yet available in the US.
The MM180 is available in the middle of US (Miller likes to be quiet about releases until it's available nationwide which will be by the first of the year according to my rep.), it is also being sold right now on Ebay by IOC. From what I understand there is quite a bit more than just the +5 amps, I know for sure that there is a means (switch?) to disable the WST feature (a very good thing IMO) plus other stuff we don't quite know about. I owned a MM175 (for a few months) some time back and If were me I would wait until I could test drive the new MM180, the Lincoln 180C & T, & the HH187 before buying.
Regards, George
Hobart Handler EZ125 - IMO the best 120V Flux Core only machine Miller Dynasty 200DX with cooler of my design, works for me
One major improvement on the MM 180, over the MM 175, is arc starts. The MM 175 is somewhat stickout sensitive. The MM 180 on the other hand will fire off a good arc start everytime, even with a 1/2" stickout. I also noticed in wire speed tracking mode, the MM 180 is much easier to dial in a solid metal transfer on, then the MM 175. Supposed too, there have also been some improvements made to the output that I haven't got to see yet, because they were done after my field testing of the unit. Hopefully soon though, I'll get my quick look at one of these updated units to check out how much of an improvement was made.
On the MM 180 to go from wire speed tracking mode, to constant wire speed mode, requires a little more then flipping a switch. As a matter of fact, there is no switch. To accomplish the task of going from wire speed tracking to non-wirespeed tracking mode, requires the following procedure:
Power down unit.
Turn wire speed dial to mininum setting.
Turn voltage dial to maximum.
Pull gun trigger, and hold.
Power up unit, while still holding gun trigger down.
Hold gun trigger for at least one second, then release it.
To put the unit back into wire speed tracking mode, requires following the same procedure, except you turn the wire speed and voltage dials in the opposite directions.
Power down unit.
Thats cute, I would have liked a button better Thanks for the info.
Regards, George
dose kinda seem like a bit of a hassel that a flip switch would have solved, also how do you know what mode its in with this method ?? with a flip switch one quick glance would tell ya.
i must say for such a smart inovative company that was kind of a bone head move, would have been les expensive to add a switch then all the sensing equipment needed to understand the switch internaly. perhaps that was just the process during the testing fase and it will come out with a flip switch ??
thanks for the help
sigpic feel free to shoot me an e-mail direct i have time to chat.[email protected] summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out.
My guess is that the average buyer wouldn't even read the manual to even know that WST existed and would probably never notice it anyway, just like most current MM175 users. Now, the more educated, like our readers, will likely just turn it off right away and never turn it back on.
true, odds are you will only use it one way or the othere. not to likely to be switching back and forth, you eather want it or you dont.
and like ya said most will never even know its there much less know the diference even if they do read it in the book.
thanks for the help
The information I get is that it comes turned off and you have to turn in on, that is if you care or even know about such things.
Regards, George
I wish they'd put a functions adjustment button on the 250dx too...
It's pretty half assed to need to "power down and up and wait for something to display and then hit this button while holding this one, turn around three times and count to 8, then divide by 3 multiply that by 4 and then turn the power off again" just to change a hot start to a soft start or something else as simple.
Would another function button really be that difficult to add since it would allow you to shorten the users manual by 10 pages? Surely, there's merit to making it easier.
Syncrowave 250DX
Invison 354MP
XR Control and 30A Airco MED20 feeder Thermal Dynamics Cutmaster 81 Smith O/A rig And more machinery than you can shake a 7018 rod at
