Weld/cut fumes
  • Weld/cut fumes
    My home workshop is 1/2 my two car garage (the wife will never give up her side ;-)) When working on projects with the doors closed (winter) I can start to build up some fumes. Since I'm fairly new to metal working, I was wondering how other people deal with this situation. Also - how much welding/cutting can I do before I have to be concerned about the fume level?
    Chop it and ride it,
    Tim
    Tim
    Lincoln SP135T
    Miller Spectrum 375
    I would install windows that you can open and keep the garage door open a bit. It doesn't take much to be harmful either.
      Would it be possible to install a " dryer vent " from inside the garage to the outside?
      Then you could develop a vent system using flexible plastic like hose say 4" in diameter, build a fan in the line to vent out the fumes. Perhaps something that you can move around and position near the work piece.
      Woodworkers install elaborate dust collection systems to extract saw dust from thier shops. You could do something along those lines.
      The other simlple solution would be an exhaust fan in a window, and another window open. ( though in winter it gets cold )
      Check these sites you might get ideas ...
      http://www.rockler.com/CategoryView.cfm?Cat_ID=237
      http://www.rockler.com/CategoryView.cfm?Cat_ID=501
        It's interesting that you said this, as it's exactly what I attempted to prototype. The problem I had, was that as soon as I put the hose on, the slowed the in-line fan down to the point that the air flow was almost non-existent. The instant I took the hose off - you could hear the fan ramp up in speed. Maybe I need a more heavy duty fan, but I have not found one yet.
        Tim
        Lincoln SP135T
        Miller Spectrum 375
          Look into the blowers designed for dust collection .... they are designed to pull wood chips, and saw dust. I use one made by Jet ... it does quite the job.
          It sits outside and I hook it into the plumbing when I work and bring it back it when I am done.
          I have a unit like this --> http://www.rockler.com/product.cfm?page=11239
            what you need is a squirle cage fan or one like vthey use as a blower on a wood stove also you cuold use a shop vac and put a hood over it that vents to the out side. good luck ....garth
            [email protected] trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
              I use a dust evacuation system what is built on the stuff from the wood working shows. It works well.
              I weld in a 2 car garage and during cooler months, I have two options, open the window some to let air in with evacuation running as the exhaust or my other option is to stay in bed.
              You have one life, don't ruin your health.
              Jerry
                Jerry
                Wow - great replies guys. I'm getting the idea that the fumes are 10 times more harmful than I thought. I don't think I'm doing the degree of work that you all are doing, but just the same it starts to stink in that garage. I guess I need to get more serious about fixing what I thought was a small problem. By the way, my garage has no windows (by design), so I will have to knock a hole in the wall.
                Tim
                Tim
                Lincoln SP135T
                Miller Spectrum 375
                  Smoke alarm problems
                  One other thing.... Since I have been more serious with the welding/cutting work I do in my garage, I installed another larger fire extinguisher, and a smoke/co alarm. The other night, when I tested my new spectrum 375, I set off the smoke alarm after only a couple cuts (a few inches each) through 16ga. How do you guys set up with alarms? I can't have that thing going off with every little bead or cut. I have it mounted on a beam on the ceiling about 8 ft from my welding bench. Would a different location work better?
                  Tim
                  Tim
                  Lincoln SP135T
                  Miller Spectrum 375
                    Be aware of your sparks too. If your garage is like most garages and that you share yours with you wife car and stuff; you can easily cause some damage to you garage and home.
                    Plasmas are great for cutting and for starting fires.
                    Just my 2 cents....
                    http://www.jhchoppers.com
                      Just my 2 cents....
                      Absolutely. Normally I move her vehicle out before working, and just about everything else that people normally put in a garage (especially flamables) has been moved to a garden shed. I started about a year ago slowly progressing my "garage" to a "shop" which my wife can still park in. Basically, my side is 100 percent work space while her side is part-time extra workspace.
                      Tim
                      Lincoln SP135T
                      Miller Spectrum 375
                        I have two extinguishers in the welding and blacksmith area. Then I have a couple more spread around the machinery area. At every door way and every work area I have fire extinguishers.
                        Smoke detectors can be useless in some areas, due to the smoke that is generated, and in some cases, the steam of some projects will set off the detector.
                        If you need air exchange put dyer vents in, one for intake and one for exhaust.
                        Jerry
                          I have the same issue with my wife, I am considering updating my wife!
