electric sliding gate
  • electric sliding gate
    Hi
    Iam going to build a electric sliding gate 18w,8H feet.And Iam going to put
    wood panel on it . plz somebody can give me some infos ,Were do i start?
    Is someone have any diagram? what kind of welder and rod i should use?how do i cut 3inch sq pipe.I have 120v access
    plz someones help
    questions
    georgerk777
    First, what kind of welding experience/machine do you have or have access to?
    Second, there's a lot of preliminary decisions to be made. Is it going to be chain driven, screw driven, or some other style of drive mechanism? Is it going to ride on rollers, a rail system, or something else? Will there be a top roller support of some kind to aide in vertical stability while it operates?. What is the evironment surrounding the gate area? Bad slopes or other difficult terrain to have to compensate for in the design? Will it be remote controled, key pad controled, proximity sensors for auto opening? Is this gate mainly for ornamental use, or does it need to be geared more for security? That's the ones that come to mind at first thought. SSS
    Bobcat 250, MM 210, Syncrowave 180, Spectrum 375
    1 Thessalonians 4:11-12
      Hey, SSS,
      I think you may have scared him away!!!
      George, are there a lot of gates to look at where you live? Be easier to see what you want, then you can answer SSS's questions. If you like or if it would be helpful, I could take some pics next week to give you an idea of what he's talking about...
      bert
      I'm not late...
      I'm just on Hawaiian Time
        Originally posted by Bert View Post
        Hey, SSS,
        haha one down a lot more to gojkjk.
        welding...its awsome
          Originally posted by SkidSteerSteve View Post
          georgerk777
          SSS is correct. There are lots of factors to consider if you're building a gate. I had a 38' slide gate built. I had to get a commercial gate motor (Elite made by Chamberlain). It has 2 1/2 HP motors running in parallel.
          I would not want to try to build my own even if I had the time to do it. No doubt that it would not have looked or worked as well as a professionally built unit.
          Millermatic Passport Plus
          Millermatic 350P with Python
          XMT 304 /w S-64 feeder and 12VS
          Dynasty 300 DX
          Thermal Arc 400 MST
          Premier Power Welder for my trail junk.
            Yeh but the last time this guy logged in was back in november
              Opps may of scared him off!
              Inferno Forge
              Chris
