Polishing Stainless Steel
  • freerider712
    scotch bright
    thanks for the suggestion. I picked up some scotch bright to try out.
  • jfsmith
    I would do the Scotch Brite thing, but start with Grey stuff then go to white stuff. As that I can not see the project, a palm sander maybe useful for doing this if the job is large enough. I think most wood working stores carry the different colors (color denotes the coarseness) of Scotch Brite.
    Jerry
  • garth
    Hi there migth want to try a scotch brigth pad back and forth on a scrap piece this may give you the brushed look you want good luck
  • freerider712
    started a topic Polishing Stainless Steel
    Trying to get a #4 food service finish on a stainless project I am working on. I'll have it welded up this evening. Does anyone have any tips before I start the grinding and polishing process. From what I understand the #4 finish is the brushed finish, not the high gloss.
