You might be a weldor if....
  • $10 for a hoe? not bad.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    • YMBAWI you know that you can't fart while wearing your new ADFLO.
      • YMBAWI, your trying to keep this going so skidsteer steve has the longest thread to date.
        TB 325
        TB 302
        dynasty 200sd
        spoolmatic 30a/wc24
        miller 211
        evolution rage 2
        • YMBAWI....
          you have ever done a job off of a set of plans drawn on your truck bumper with soapstone.
          my daddy always said i was IRONHEADED....
          feel free to P/M me
          • YMBAWI every time you go to the welding store they give you a box of soapstone and they saw it is because you are their best customer
            This is an automotive discussion forum that has some great infromation
            www.autobodytoolmart.com/shoptalk
            • What do you mean GOT from the kitty box? If my cat would of seen my welds, he would have taken them to the box himself and buried them DEEP! Then dumped on them. No chance of them seeing daylight again soon!
              • YMBAWI when caulking walls for the painter you pretend your welding them. that's what i have been doing for the past two weeks. maybe ill throw the hood on without a shade in it.
                • YMBAWI----you come in late from the shop, wife is alread in bed, lights out, so you slip into the bathroom, brush your teeth, strip and hit the hay! Wake up at 0 dark 30 to the wife screams when she looks at you and your answere is "WTF" is wrong??? she says get out of my bed and look at yourself!!! You check the mirror and realize you are still covered with grinding dust, smoke and you still have your favorite welding hat on!
                  sigpicRetired Elevator Consrtructor Local 19 IUEC
                  AK bush pilot (no longer in AK) too old and no longer bold)
                  Chaplain CMA chapter 26
                  Dynasty200dx (new and loving it)
                  MM-252 (NEW AND LEARNING IT)
                  Hypertherm PM-45
                  Miller 140 mig 110v
                  Vtwin builder
                  • I smiled as I read that one !! But I laughed like a fool when I got to the hat part.
                    BTW : The wife wants to know why there is rust on our bran spanking new toilet. She said that she was unaware that porcelain would rust. So I had to tell her that it wont but the metal particles from the grinder will. After a close look she has proved to me that the little particles even etch themselves into the porcelain.
                    My only response was ( I thought I was suppose to wash up after i pee ) , she didnt think that was funny at all.
                    Tom
                    Miller 211 A.S. and Spoolmate 100
                    Stickmate LX 235 AC / 160 DC.
                    Clarke 180 EN Just in case
                    Spectrum 375 X-Treme.
                    O/A Medium Radnor Torch, Large Victor Torch.
                    Milwaukee 14" Chop Saw.
                    4 x 6 Horizontal Band Saw.
                    Rockworth 80 Gallon 2 Stage 16 SCFM @ 175 PSI , 15 SCFM @ 90 PSI.
                    Jackson Passive shade #5 for the plasma.
                    I almost forgot the Hobart XVP AD Hood.
                    Projects and Misc Albums
                    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
                    • Good one Tom!
                      It reminds me of when I was twisting wrenches and we used to say you could always tell a Mechanic as he always washed up before he went to the stall! The evidence of poor hygene was when you put your shorts in the Laundry tub!
                      Tim
                      Hypertherm PM-45
                      Miller 140 mig 110v
                      Vtwin builder
                      • YMBAWI : You break for lunch. You don't remember putting ketchup on that sandwich in your hand. Then you casually realize that your bleeding again.
                        Miller 150 STL
                        • YMBAWI---you pick up a new striker and chipping hammer every trip to the LWS and then when you can't get the seat to move in the truck you find the last ones!!
                          YMBAWI-if you use the OA torch to find your soap stone that "must have fell out of your pocket behind the steel rack?
                          YMBAWI---if you use the cup and cork off your stanley as a plasma cutter guide!
                          YMBAWI----If you were offered a job as a beach lifequard and you turn it down cause you have a Fab job that you started and you are determined to finish!!
                          Tim
                          Hypertherm PM-45
                          Miller 140 mig 110v
                          Vtwin builder
                          • You Might Be A Welder If:
                            You've been fixing a crack in a friends transmission bellhousing overhead, before feeling the wonderful sensation of molten aluminum brush past your genitals.
                            You've finished a weld on the roll cage you were fitting to a miata, before squirming around like a worm on a fish hook, trying to get the spatter out of your welding leathers.
                            You've ever been set on fire from grinding sparks, after finishing your welds unscathed.
                            You look like you changed skin colors after grinding all your welds flush with the base.
                            You can no longer go to a car show because you tear the welds on the displays apart more than you look at the cars.
                            You forget that you are on a time limit at the library, and almost miss posting this.
                            Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
                            • YMBAW if you try to convince your wife that the rust stains in the driveway enhance the value of the home, just like a professional stain job..
                              • YBAWI You were changing tires at a friends house on some farm equipment with a 1/2" breaker bar and after trying for a while you think [email protected] I wish i had a torch with me
