You might be a weldor if....
  • When you go to try to drawl a strait line and try to weave it like a whipping rodComes to be very agrevating in the future
    • YMBAWI: Someone asks you if you are a welder, and you reply, no, I'm a Mechanical Fusion Engineer.
      Jonny
      Dynasty 300DX
      Esab PCM 1000
      • YMBAW if someone asks you a question about anything and you know the answer.:
        miller big 40
        miller big 30
        miller pro300
        miller s21e
        miller sycrowave 250
        miller spectrum plus
        • YMBAWI you go to make a line with a pen and stop to think if you should go vertical up or down!
          I did this the other day when marking a piece for the tourch and thought of this thread right away.
          • will it weld
            YMBAW... If you prefer to breath ozone rather than oxygen .
            ... If you look around the world at the trees and the animals and
            everything and wonder if you can weld it.
            There is a video on Utube called "will it blend"... where is "will it weld"????
            Miller 251/30A spool
            Syncro200
            Spectrum 625
            O/A
            Precix 5x10 CNC Router12"Z
            Standard modern lathe
            horizontal 7x12 bandsaw
            Roland XC540 PRO III
            54" laminator
            little dog
            • ymbawi... you are given a phone number that ends in 6061 and immediately take an in head inventory of tig rods in your shop.
              ...if you know the color difference between a 5p and a 5p+
              welder_one
              nothing fancy, just a few hot glue guns for metal
              www.sicfabrications.com
              • ymbawi: Your friends don't invite you over their parties anymore because every time they send you out for some Miller, you always come back with something big and blue that gives them more of a jolt than they had in mind - especially when they try and drink from it!
                • ymbawi...you've ever gotten a "nuclear sunburn" through a t-shirt. (spray transfer on heavy aluminum) burnt right through
                  welder_one
                  • Originally posted by gunruner View Post
                    YMBAWI You bend a welding rod in half and put it in a hasp instead of a padlock
                    YMBAWI If you come across a door with a hasp and a bent welding rod in it, and respect that its “locked” and you do not open it.
                    i think im guilty of this one
                    my daddy always said i was IRONHEADED....
                    feel free to P/M me
                    • ya might be a weldor if....
                      you make your own stainless tooth picks.
                      .....i have a can of them i made from filler rods
                      feel free to P/M me
                      • odey
                        Your workday starts with a spark.
                        • odey
                          Youv'e got a rod for every occasion.
                          • odey
                            Your prefix name is SOS==Surgeon of Steel ie. SOS Odey
                            • odey
                              You wear flowery but reversible caps.
                              • odey
                                You carry wood wedges and JBweld under your truck seat, & the bottom of your toolbox and always have a big mouthful of the stickiest bubblegum.
