c chanel
  • Star1280
    Well I did ok. My main problems were starting off, getting the plate hot enough so the filler would take and then slipping the filler in without contaminating my electode.
    In order to get into the corner of the fillet is there a recommended length of electrode tip? Is there a recommended angle on the torch and filler. A lot of the time I found my self chasing the filler around. Especially at the start of the weld, it would pull back and ball up from what ever wasn't hot enough. And then when I heated things up considerably the thin c-chanel would burn through. It really made an ugly beginning but by the end it evened out.
    Any more tips would help before attacking the real thing.
    novice
  • Star1280
    Thanks Mac702-
    I will go and get confortable on some practice pieces and let you know if I have any problems.
    I like the idea of the plate being flat.
  • MAC702
    Welding each bead in the flat position is best, but that may mean you have to hold the weldment at an angle. Horizontal is next best, and may actually help you here as you can keep the plate in the flat position and it will be easier to concentrate the heat on the plate and manipulate the puddle to incorporate just enough of the channel for a solid weld.
    Keep in mind that this joint is even more challenging because the thinner channel is also at the end, which melts much more easily than the middle of a piece, such as the plate will be.
  • Star1280
    True on the fillet (long day), parts are solo so I can do it on the bench which leads me to the next question. What is the best position and torch angle. I'm thinking of clamping the two and positioning myself over each fillet. Is this the best way?
    I only have a tig welder and suck at stick.
    thanks again!
  • MAC702
    Originally posted by Star1280 View Post
    All is correct, thanks for responding. I haven't started but I know from my experience in the past, welding anything thinner to another it ends up in a big mess and I have to use a ton of filler. Is a fillet weld recommended? I just have to make sure it sticks.The horizontal c is only 2" long so I know its going to heat up even quicker! ...
    If my assumption about the position was correct, how could you do anything BUT a fillet weld?
    Will all welds be in the horizontal position, or will some be vertical or overhead? Is this part actually ON the car?
    Why GTAW?
  • Star1280
    c-chanel
    I'm still getting use to settings and there are a lot on this cadillac. Anyone know what would be best?
  • MAC702
    I'm assuming a fillet weld? Welding the channel end to the flat of the plate? Horizontal position?
    I'd use a moderate setting and concentrate the heat on the plate and wash the puddle onto the channel. What exactly are you doing now?
  • Star1280
    started a topic c chanel
    c chanel
    Hi new to the list and new to welding, glad I found you guys!
    Can anyone give me some quick tips on welding .125" al. c-chanel to .25 plate without blowing though the .125" C-chanel? I am using a 350 Syncrowave.
