I saw a set up once with a gang of 3 old Argon/CO2 welding tanks set up for a air compressor.
These tanks also were short a few holes for drains, outlets, inlets, relief valves, etc. The guy mounted them upside down in a rack with the outlets at the lowest point.
Then, there was a reducing bushing, a nipple screwed in each one, and a few 'T's. The various 3rd points on the 'T's became outlets, inlets, cross overs, pressure sensor for the pump, and 'T's in the horizontal connecting pipes between the tanks had a relief valve, and finally a single drain outlet on the lowest point of one end. It was well thought out, and the manifold going across the bottom did everything it was supposed to do.
