welding aluminum beer cans
  • Sberry
    Rumor has it that Century used to have a factory rep that would weld those cans together with a 120V mig doing demonstrations.
  • Rick Eis
    Welding cans with a 200dx
    OK...I have read this thread many times and found many ideas. But what I am looking for is a photo of the best weld with the detailed setting info etc that was used for that particular weld. So submit a photo with the detailed settings...thank you. Rick
  • jontheturboguy
    I know Im digging up an old thread, but any body have any more pictures?
    I was thinking about trying this again, as over the weekend I saw one of the new Bud Lite Aluminum "bottles" and noticed how stout the aluminum was compared to a conventional can.
  • vin-man welding
    so i bring the two cola cans welded together to a friend of mines shop.(not a welding shop). and it's funny how many people say how easy it is. then my friend tell's them to duplicate it and they stop telling. people are just amazing. if they now how to weld at lest they might know the cans are aluminum.
  • On fire most of the time
    ...I never welded anything to it...props. I just ran the bead and tried to keep it consistent.
    Imma have to find myself a tig welder I can use, and keep playing around.
  • Xwelder
    Originally posted by vin-man welding View Post
    Xwelder said the side was harder so here is my side shot. i have to weld some alum tomorrow so i used a piece of the stock. it's 1/8.
    the two holes are from the cup. (the sides sure are thin)
    That's impressive.
  • vin-man welding
    Ive found that Monster cans work rather well...just scotch brite the paint off, and get bare alum...go to town.
    I used an 1/8th" 2% thoriated electrode, used some 1/16th" rod (3003 I think), and set max at 15 amps. On a Lincoln. Gas flow was about 10cfh.
    Ive tried welding cans the same way with a miller...doesn't seem to work as well, but again, so many settings I had no clue where to put them all.
    The best bead I ever had was on one of the 24oz'ers and I ran from the top ridge to about an inch from the bottom before I finally burned through. Great practice for consistency, and pedal control though!
  • vin-man welding
    and here is mine. i only had 3/32 filler and haven't welded alum in a long time. i should have toke more time with it but just banged it out to show some one. and i didn't use any fancy settings. it is the second one i did, the first one had a grounding issue and the hole side of the can blow out.
  • Xwelder
    Not two cans together, but this part of the can is thinner.
  • Ultrachop
    Tecknition,
    Congratulation on the purchase of the 200dx, I am picking mine up "today". I am as well looking for a new Plasma cutter, we will stay intouch and compare notes!
    Tim
    [QUOTE=teknition;2770]I recently purchased a Miller Dynasty 200DX and want to practice welding thin aluminum.
  • wrh5
    Welding beer cans
    Hi
    Is this what you had in mind?---I having been doing this for years using a Miller Snycro Wave 250 :-)
  • weldingtipsandtricks
    welding beer cans with a dynasty 200dx
    A few tricks for welding the beer cans with a dynasty 200dx:
    First thing is punch a hole in one of them so that the expanding gases dont blow out when you close up the last little bit of the weld.
    second, use 1/16" or even .040" electrode, either 2% thoriated, ceriated, or lanthanated and put a taper on it just like you would for welding on DC. maybe not quite as sharp.
    A/c balance around 60, frequency/HZ at about 100-120
    Filler metal no bigger than 1/16"
    use 4043. 4047 is even better because it has slightly lower melt point and wets out better with lower heat.
    If you really want to strut, run a really light pass around the ridge of each can where the weld will be, in addition to all the above.
    Good luck,
    Jody
    www.weldingtipsandtricks.com
  • techwelder
    Welding Beer cans
    Hello,
    Currently I have 6 250's in the shop that I instruct in. I have found that using a piece of angle iron to help fit the 2 can together is beneficial. Pre cleaning the cans with a stainless or brass wire brush is a must. My students practice with 1/16" 2%thoriated and we use 4043 .030 spool gun wire. After the 2 cans are tacked, the arc must be concentrated in the center of the tack to begin the welds. I have found if the cans are not cleaned properly by remiving the clear coat the arc will take the least path of resistance and melt a hole in one of the cans. A steady hand is a must, and the rate at which the filler metal is added is essential.
    Hopefuly this helps,
    Adam
  • benny365
    All aluminum cans have varnish on them to keep the liquids from eating a hole in the can body, 115 Milligrams to be exact. Oh and the frost brewed liner on the Coors cans is Bull****, just blue varnish. As long as you don't burn through you should be safe from contamination
