welding aluminum beer cans
  • #31
    MIne look about like the onse above, but my big issue is the arc wanting to jump to one can and heat it up perfect and the other stays to cold.. a bit of torch manipulation helps though.. I've played with all sorts of settings and being that i've only played with pulsing a handfull of times i need more practice with it to get good at it.
    I will have some pics of my attemps up soon enough.. **** tonight i may even post the few i've already done.... In my "mini-lab" thread in this section there is a can to can weld in the first post the name i s "redbullhalfa$$" or something with "halfa$$" in it.
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
    Just about every other hand tool you can imagine
    • #32
      Turbo...........
      You have to tilt the torch/arc more towards the direction of travel than normal, while keeping the filler in the leading edge of the puddle. Weave the torch, or fillet if you feel like it.
      SYNCROWAVE 200
      Atlas 618 lathe (vintage 1960) reconditioned DC
      Sioux 3/8 Pneumatic Reversible Drill
      Makita Everything else
      2400 square feet of Sanford and Son lookin shop space
      "Once the spoon flys, putting the pin back in won't solve anything"
      USA 15T, 15V
      www.myspace.com/blackbird455
      http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
      • #33
        As I mentioned in another thread.......
        the .040 tungs didn't work out too good, it caused alot of instability and wobble even burned through in a couple of places.
        SYNCROWAVE 200
        USA 15T, 15V
        • #34
          ok when i did it i wish i had back gased, had a smaller tung, and smaller filler. but i did it and got a 4 day weekend out of it. i had my machine maxed and was using the pedel had a pure 3/32 tung 4043 1/8 filler my balence was in the middle (its all wrighten in german) and i think the freq was around between 175 and 200 hz and the tung was balled i dont have pics because the recovery ncoic crushed it befor i had a chance.
          weld to live live to ride
          • #35
            Hooraaah!!! I did my first can with no holes what so ever!!! The only prep i did was take a piece of "fine" scotch brite pad (the stuff used in auto body shops) and scuffed the bottom of both cans, no wire brush, no acetone or anything else
            The settings were as follows
            Main Amperage = 20 amps
            Start Amps = 10amps (Default start time and polarity)
            Torch = 0.040 thoriated ground just slightly with a # 4 cup on a WP-9 torch
            Gas = 100% Argon at 11cfph
            Pulse Settings
            P.P.S. = 5
            Peak = 80%
            Background = 40%
            Balance = 70%
            Frequency = 67Hz - pretty low for an inverter machine IMO
            I think i could have dialed in 5-10 more amps in the main control to smooth out the "blobbed spot" that formed after I accidentally dipped and contaminated the tungsten But, instead of stopping to fix the tungsten i just kept on welding, said to myself "just said what the heck, I've burned holes in all of them so far anyway".. LOL
            Here's some pics as proof... some are a bit blurry, i suck at macro pictures HAHA (there's also a pic of some little objects that came from boredome... I cut the letter G from 1/4 inch steel with a oxy torch... not bad for me IMO )
            EDIT: I didn't take any pics, but today i used a # 3 oxy welding tip and some "alumiweld" brazing stick that i got at harbor freight Saturday and my god was that not only easy as could be, but the appearance was great too (save for the burning of the paint and discoloration of the can where the labeling is from radiant heat)
            Hobart Handler 135
            Lathe/Mill/Bandsaw
            • #36
              We know you have a camera, so....... no pics; no braggin'.
              OBTW: Nice job on the Hooraaah!!! And thanks for the detailed settings, even though I can't use 'em on a Syncrowave.
              RETIRED desk jockey.
              Miller Syncrowave 250.
              • #37
                Nice TG!!!
                SYNCROWAVE 200
                USA 15T, 15V
                • #38
                  I first welded two soda cans together at work when i had nothin to do i did it with a syncrowave 250 with no pulse or anything. I got it my first try it easy now. Has anyone ever heard of anyone actually welding aluminum foil together.
                  Thermal Arc GTSW300
                  Syncrowave 300
                  Handler 125
                  Acorn Table
                  • #39
                    There's actually a video of a guy welding Al foil together on here. If you look up the instructional videos on the Miller website there is samples of the video and he shows how to do it. I'll try it tomorrow...
                    Steve
                    Syncrowave 250 DX
                    Millermatic 252
                    50 amp Plasma Cutter
                    Big Brute Rotary Draw Bender
                    Custom Tubing Notcher
                    Holland Mill
                    Atlas Lathe
                    etc, etc.
                    • #40
                      i have seen that but he is kinda cheatin and i mean truly welding it together like two flat pieces on a table never the less that is a pretty cool trick
                      Thermal Arc GTSW300
                      Syncrowave 300
                      Handler 125
                      Acorn Table
                      • #41
                        Hey turboglenn, I made those cans!!!
                        That code on the bottom of the first picture means May 6th 2008 A = Day shift #3 Decorator plant 66. I worked that day!!!!!
                        One of our customers is pepsi omaha, we ship alot of cans down there.
                        I am honored to have made those cans for you to weld.
                        there is actually varnish on the very bottom of the can to help it slide during production, make sure to grind that off. in the dome there is no varnish.
                        MM 211 W/ Spoolgun
                        Diversion 180
                        Spectrum 375 X-TREME
                        Portable Victor O/A
                        Palmgren Bench Drill Press
                        14" Evolution Dry Saw
                        IR 60 Gal. 3 HP Compressor
                        Speedglas 9100x
                        My Brain
                        • #42
                          That's pretty cool to know I wonder if the latest ones that i've done were made by you as well? I'll have to post up pics tonight or so. I've got a lot going on with my woman leaving for San Antonio Tx (she's air force) and have been just busy as **** here the last few days. I'll post teh pics where we can see the numbers on them as well
                          If you ever get out this way to go to the plant hit me up and you can stop by and burn some rod on my machines or whatever.
                          Glenn
                          Hobart Handler 135
                          Lathe/Mill/Bandsaw
                          • #43
                            Man, I'm going to have to be nicer to people.
                            It sure is a small world!
                            • #44
                              There is actually varnish on the very bottom of the can to help it slide during production, make sure to grind that off. in the dome there is no varnish.
                              WHAT!?!?! So how long have YOU been doing that to me?!?! Seriously, how long have the bottoms been varnished? I've toyed with welding cans for awhile, some OK; some real bad.
                              • #45
                                First attempt to TIG weld two pop cans together.
                                -I also found that it was difficult to melt both sides.
                                -The heat always wanted to go to one side.
                                -The following were my settings:
                                Main Amperage = 30 amps
                                Torch = 0.040 Tri Mix ground with 1/64" Flat
                                Cup = # 4
                                Torch = Weldcraft WP-17
                                Gas = 100% Argon at 12cfph with a gas lens
                                Rod = 1/16" 4043
                                Balance = 70%
                                Frequency = 150Hz
                                Miller Thunderbolt
                                Smith Oxyacetylene Torch
                                Miller Dynasty 200DX
                                Lincoln SP-250 MIG Welder
                                Lincoln LE 31 MP
                                Lincoln 210 MP
                                Clausing/Colchester 15" Lathe
                                16" DuAll Saw
                                15" Drill Press
                                20 Ton Arbor Press
                                Bridgeport
