Cast Iron Repair
  • Cast Iron Repair
    Hey guys. I've been reading for awhile,first time thread.
    Need to repair an equipment roller made of cast iron. Any suggestions?
    I have some hobart 99 but I read somewhere else it should only be used as a single pass. Use 99 for the root and Hobart 55 for the cover passes. Also should I preheat the whole thing or just around the weld area. The ground out area was a crack and on the broken side I want to replace with hot roll.What can I do to attach hot roll to cast?
    TJ
    Miller Syncrowave 250
    Miller CP 200 w/S21-E & Spoolmatic 3
    Miller Bobcat 225
    Hobart R-300
    "There are two kind of people in this world. Those who can weld and those who can't." Jesse James
    If you are sure its cast iron just use a good Ni cast iron rod. If it is cast steel use 7018. Be sure to give it a little preheat before welding...Bob
      Kinda looks like steel to me. Shiney bluish tint where it's clean ground. Maybe a forged steel or cast steel part. If it is iron and you have to pre and post heat make sure you isolate those rollers if they have bearings in them.
        I think you guys nailed it. Cast steel. Did a spark test and sparks just like steel. What about tig on cast steel? TJ
        Miller Bobcat 225
        Hobart R-300
