Did this yesterday,1/2" plate someone did was cracking in mutiple spots.Replaced with 5/8" saved d-rings added gussets in the back at 60deg. inward toward center.All mig off my MM250X 70S6 .035 wire.Except top of plate under dump hinge sticked that 7018 1/8.Wire wasn,t wetting in the way i prefer.
F-800 Pintle plate
Originally posted by bigtow30t View PostThat looks heavy. Did you put any channel or anythingon the back side to keep it from bowingBB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
I had the same question, I normally run a stiff back also because thats where they fail, unfortunately it was hard to see if the gussets were on an angle from the picture.
I do agree, if he was a dirt digger hauling a 24 ton trailer then I would say you need to beef it up, but for hauling a 10,000 lb chipper that should be plenty, especially since you angled the gussets in.
In a worst case scenario all that would happen is it would start to bend if he over loaded it.
Nice job.
