The arms on one side of my customer's pallet jack broke. To remove the arms it was necessary to press out the shaft that the arms pivot about. The shaft is retained by a blind roll pin loaded in double shear. The blind roll pin was flush with the surface so I had to build the roll pin up with weld so that I could remove it with a slide hammer. My customer had cut out a portion of the bushing that retained the shaft in an attempt to free the pin.. Unfortunately the pin was also engaged on the other side, which was more than adequate to resist the hammer blows attempting to remove the shaft. I welded up the bushing. Last but not least I noticed that the bearings were shot.
Don
Don
