I picked up a side job from work about fixing a drawer for them. I am a welding student looking for practice so this is good. It is a ss drawer that pulls out and it is supposed to have a back plate stop so the wheel stops at that point. I'm going to have to cut out about a 3/4" or 1" piece of ss and weld it on the end. Problem is it being so thin (16/18 gauge) I would like some opinions on what type of wire I'd need. .023 .030 .035?
Stainless Steel Repair
Last edited by MillerWeld; 03-30-2015, 11:44 AM.My Blue Stuff: Millermatic 211 Auto-Set
You know you're a welder when... You miss your court date because you stood outside the courthouse looking at the welds on the handrails.
"If the thats the worst thing that could happen to us all day, then we'll be doing pretty good"Tags: None
Originally posted by aametalmaster View PostIf you can find .023 SS wire go for it. If not use what you can get...Bob
My point was that we need more info before we can give him the best advice..
the stuff could be paper thin or maybe 1/8th inch... as it stands.. we have no way of knowing..
BTW... .023 308 SS is readily available..
http://www.usaweld.com/023-308-Stain...ol-p/30223.htm
You are right and the bad part is all of the tacks/weld are on the outside of the corner. Which over time and pulling/slamming the drawer out to the stops it will just break off again...BobBob Wright
I do a lot of ss work for the Wendy's resturants near me and its all thin gauged stuff.i use .23 or .30 wire.. also a lot of the welds tend to break a year or so later and I just go back and re teck them.ss is nice but it'sbrittle and does crack a lot on stuff that is slammed around being cleaned and opened and closed all the time.
