Oh yea, the "mandatory" first cart project...
  • Oh yea, the "mandatory" first cart project...
    Hi all,
    I've been taking a basic welding class at our local community college and after the first month or so, decided to pull the trigger and invest in my own welder, a MM211.
    The instructor asked us all to come up with "class" projects that we could work on. I knew that I wanted to make a cart for my new welder, so I surfed around the interweb and looked at a bunch of carts to get ideas. I then drafted up (old school pencil on graph paper!) some scaled drawings to work out my materials and cuts.
    I knew that I wanted a cart that could be pulled across uneven ground or gravel drives since I'll need to move the welder around the farm. Big wheels and castors with a wide stance and the welder securely bolted down and the cylinder not wobbly were requirements.
    I also liked the carts I saw that had cantilevered shelves. They seemed to offer good and unimpeded access to storage areas. I wanted a storage shelf that had fairly tall sides to keep tools and supplies from rattling off the edges.
    I wanted the welder up high enough that I could change the wire without having to stoop or sit on the floor, same with reaching the front knobs. This height stressed the need for a wide stance and stability.
    Finally, I wanted a design that would protect the front and rear of the welder and allow me to rotate the regulator and gages on the cylinder to a position that was protected from bumps and knocks. Things can get a bit rough around the shop and barn.
    I didn't take many in-progress shots, but here are a couple:
    [IMG][/IMG]
    [IMG][/IMG]
    You can see my inexpensive Harbor Freight cart in the background. (One of my classmates has already offered to buy it from me. It worked, but it's none too sturdy, and it's very hard to move around on anything but nice smooth concrete.)
    Here's my cart at school, ready to clean up for the final paint:
    [IMG][/IMG]
    Well, bother...
    Ten images and a limit of 4 per post. Guess I'll break this up into multiple posts.
    Hope cut-an-paste will save some time. We'll see...
    So, continuing on...
    And here're the final results:
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    I added a holder for the cylinder cap to keep it from rattling around:
    [IMG][/IMG]
    And, to be continued!
      (And the stunning conclusion!)
      I wanted a secure and snug fit with the gas cylinder itself:
      [IMG][/IMG]
      [IMG][/IMG]
      The rubber noise isolation was cut from the end of a shop floor mat and glued on with contact cement.
      Here's the "holster" for the GMAW gun:
      [IMG][/IMG]
      The cart is very stable pulling it across the ground from my shop to the barn or other places around the hacienda.
      The rear wheels are 10" "no flat" wheels from Harbor Freight. The front castors are 4" from the same vendor. I used spring lynch pins to keep the rear wheels on since these let me remove the wheels easily as I was working on the cart over time. The rear axel is 3/4" .065 wall tubing.
      The blue paint is Rustoleum "Sail Blue." It's not an exact match for the "Miller Blue" on the welder, but it's as close as I could get without too much expense. (I shopped hard in my local area for one of the OSHA / federal "Safety Blue" paints in the rattle can with no luck.) I applied the blue over a self-etching primer after I gave the cart a final wipe down with lacquer thinner.
      The front handle extension seems to offer good protection for the front of the welder and the cables. It's at a good height to lift the front of the cart up onto concrete slabs or out of small holes and ruts. The basket seems deep enough that stuff will stay in it without being too deep that loading and unloading is a PITA. There's room between the cart and the cylinder for the welder power cable and gas line and the gas regulator to be rotated to the center to keep it away from knocks and bumps.
      I'm sure I could have built the cart out of much smaller materials, but the 2" square, 14ga tube has nice proportions. (I did use 1-1/2" 14ga tube for the angled braces.) That was an "aesthetic" choice rather than an "engineering" one. I just like the "looks" of several other carts made from 2" square tubing that I saw as I was searching for ideas.
      Anyways, it was a fun and interesting project. I learned a lot - this being the first thing I've ever built in all metal from scratch. Still, I'm pleased with the results and the cart seems to meet all of my design criteria. Guess I'll find out how well I did as time goes by...
        Looks great
        Looks like you did a great job, very well thought out. I like the attention to detail.
          Looks awesome
          Bonus style points as well
          "Beware of false knowledge; it is more dangerous than ignorance." ~George Bernard Shaw~
          Airco 300 Heliwelder
          Dialarc 250 AC/DC
          ESAB 161
          Invertec v250 and v300 Pro
          SA200
          Spectrum 700 plasma
          MM210
          Miller HF-15-1
          Dirty ugly tools - perfect
            @ hwatkins and MinnesotaDave:
            Thanks for the kind words guys! I appreciate the feedback.
            Mike
              Nice work...
              Gee looks like it might comfortably fit a Dynasty 280....
              You could add another shelf for the cooler.... HHHmmmm...
              Welcome Aboard....
                Excellent ... but no beverage holder.
                Miller stuff:
                Dialarc 250 (1974)
                Syncrowave 250 (1992)
                Spot welder (Dayton badged)
                  Pop
                  were you seeking a cupholder or a full on keg tapper....??...
                    Drink holder's optional...
                    Hey USMCPop, yea, total fail - no drink holder LOL!
                    When I took the cart into class last week, though, one of the other instructors walked through and the first thing he said when he saw this was...
                    [IMG][/IMG]
                    "Cool, but wouldn't your drink holder be more convenient if it was up higher?"
                    Thanks for the welcome and the comments, guys!
                    Mike
                      Very nice job, I too use the rustoleum blue for all my welding carts, I like your mig gun holder.
                        Shameless design copy...
                        Thanks, PW! I can't take credit for the mig gun holder, though.
                        That was one of those many good ideas that I saw while surfing around looking at other carts. I wish I could give the builder credit, but I just stuck a picture of his holder in a folder on my computer with a lot of the other nice carts I liked.
                        When it came time to design my own cart, I shamelessly just copied that bit.
                        Thanks for the kind words, though.
                        Mike
                          When it comes to a weldor, you can't beat liquid cooling.
                          Miller stuff:
                          Dialarc 250 (1974)
                            Nice job ....
                              @USMCPop: Oh, you mean liquid cooled "weldors" not liquid cooled "welders"... LOL! Could also be well lubricated!
                              Originally posted by Great White TJ View Post
                              Nice job ....
                              Thanks!
                              Weather was pretty sucky today, but I can't just sit an' do nothing. Always stuff to make.
                              So, a couple of happy hours at my grandmother's 1904 Singer Model 66, and I made a cover for my welder:
                              [IMG][/IMG]
                              Nothing too special, just a square feed sack...
                              Mike
