I need a 9/16" dia threaded grade 8 bolt welded into the end of a 1" dia forged steel crankshaft. The bolt is lighty pressed into the shaft. Not certain that the mobile welding company that I contacted actually has the expertise to do the job correctly and I would like to avoid a catastrophic failure down the road . His first attempt broke when I attempted to torque the nut onto the bolt. A crankshaft seal is about three inches away from the weld area so heat is an issue, but I feel I can keep the heat away from the seal. Looking for guidance as to type of rod/wire and pre/post heat instructions. Thank you in advance for any assistance or advice. Bill Robertson.
Tig welding a forged steel automotive crankshaft
Questions for Clarity
Originally posted by ftlrobby View PostI need a 9/16" dia threaded grade 8 bolt welded into the end of a 1" dia forged steel crankshaft. The bolt is lighty pressed into the shaft. Not certain that the mobile welding company that I contacted actually has the expertise to do the job correctly and I would like to avoid a catastrophic failure down the road . His first attempt broke when I attempted to torque the nut onto the bolt. A crankshaft seal is about three inches away from the weld area so heat is an issue, but I feel I can keep the heat away from the seal. Looking for guidance as to type of rod/wire and pre/post heat instructions. Thank you in advance for any assistance or advice. Bill Robertson.
not a good idea...
the bolt will be grade ZERO once welded...
and there is no way to restore the heat treat if still in the engine...
Is this by any chance on a Mazda MIATA engine...??.
the short version- when welding anything heat treated you destroy the heat treat, so it will make no difference if it's grade 8, 5, 3 or 0, it will be the same after welding.
I'm with everyone else, what the heck are you doing/what are you working on?Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
Actually, with low heat and the thermal mass of the crank, it could conceivably quench harden a part of the bolt at the HAZ and make it brittle. In any event, the heat treatment is messed up.Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
