How should I repair this gym equipment?
  • How should I repair this gym equipment?
    Went to my local gym today and one machine was down . The owner is a good friend , so she showed me the piece . I was surprised to see that the square tubing only had original two sides welded. I'm thinking I should add some gussets . I have a bunch of roll cage gussets , but I'm not sure of those or if I should use smaller square tubing on angles . The last picture is how it gets welded back together . Any advice would be great , thanks .
    Grind clean. Weld. Add a gusset or two and repaint. I would probably just mig it back together.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
      Thanks , that's all I have is a mig . Will the roll bar gussets be fine ?
        This time, clean it to shiny steel, turn up the wire speed a bit more hold a tighter arc, do not use a 115 volt flux core machine.
        Dynasty 280DX
        Bobcat 250
        MM252
        Spool gun
        Twentieth Century 295
        Twentieth Century 295 AC
        Marquette spot welder
        Smith torches
          The guy said he has a mig welder.^^^^
          Besides weight equipment is usually only 1/8" max a 120v 140 miller mig can handle the job
          Miller Bobcat 225NT onan
          Millermatic 211
          Spoolmate 100
          (Retapped to fit regular mig tips)
          Work better & less parts to stock.
          Miller 130xp
          T/A Dragster 85 (portability 11 pounds)
          Oxygen/Acetylene torch set 50'
          2. 4-1/2" grinders
          1. 9" grinder
          14" Makita chop saw
          1/2" Aircat impact gun 900#
            Yeah those gussets should be fine.
            MillerMatic 251
            Maxstar 150 STH
            Cutmaster 42
              Thanks everyone , I'll fry it tomorrow after work
                Pretty crappy weld there on the original.
                  Start by throwing it in the garbage before it seriously hurts someone. The rest of the welds on that gym equipment is probably welded just as solidly (or un-solidly). So it doesn't make sense to use it, unless it's for a place of business that has a good insurance policy for it's membership holders.
                    I think you can try welding for your gym equipment. you can also search for a welder online.
