Removing Rusty Ball Mount from Receiver of Trailer Hitch
  • Removing Rusty Ball Mount from Receiver of Trailer Hitch
    My customer had trouble removing the rusty ball mount from the receiver of his hitch so that he could install a rear plow on the hitch of his snow plow truck. He currently has 55 costumers so the rear hitch will help to pull the snow from the driveways. It turns out that rust has a greater volume than steel so the ball mount was now a tight press fit in the receiver. To remove the ball mount I Mig welded a 1-3/8" bar to the bottom of the ball mount so that my customer could beat on it with a sledge hammer while I heated it with the oxyacetylene torch. It was so tight that all of this persuasion was necessary to remove it.
    Don
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    Lincoln 210 MP
    Clausing/Colchester 15" Lathe
    16" DoAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    I have done similar a few times, it's a *****. It doesn't take long for it to happen either (at least in a northern state that uses salt).
    But the times I have done this it was a waste of time. The receiver tube had rusted so bad that it was so thin, I told them to get a whole new hitch. Told them I wouldn't use it to tow anything. Did they I don't know, I hope they did.
      Well I hope that there is enough wall thickness left on the receiver tube that it will hold up. It is a bolt on hitch so it is relatively easy to replace if necessary.
      USMCPOP on the Weld Talk forum suggested using a product called "Fluid Film" on the square shaft of the ball mount and the receiver socket before installation to reduce corrosion. I checked out the following link and it sounds like good stuff. It is specified by John Deere for use on their equipment and it is available from Auto Zone and O'Reilly's as well as many other industrial supply companies. Although I had never heard about it before USMCPOP's suggestion, I plan on picking up a can or two to try it out.
      FLUID FILM® is Eureka’s own unique lanolin-based brand of corrosion preventive and lubricant, used worldwide in a multitude of industries and applications.
      Don
      Lincoln LE 31 MP
      Lincoln 210 MP
      16" DoAll Saw
      15" Drill Press
      20 Ton Arbor Press
      Bridgeport
        Fluid Film is lanolin-based (wool wax or wool grease). I have yet to see a rusty sheep.
        Miller stuff:
        Dialarc 250 (1974)
        Syncrowave 250 (1992)
        Spot welder (Dayton badged)
          Iv'e used Fluid Film on my 3 point snowblowers drive chain for years, works as advertised. Keep it indoors or in a heated area in the winter or it won't spray worth a darn.
          Pete
