The last time I used my crow bar I pulled a chunk out of the jaw of the crow bar instead of pulling out the nail. It is an ancient crow bar that was my dad's so it has sentimental value. Attached is my repair.
Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
Lincoln SP-250 MIG Welder
Lincoln LE 31 MP
Lincoln 210 MP
Clausing/Colchester 15" Lathe
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
did you heat treat it after? if not the welded part is gonna be softer than the original piece and will just round off.
I was hoping that the weld would pick up some carbon from the parent metal and the rapid cooling due to the mass of the bar would harden it a little. Time will tell if it is hard enough to keep its edge. The bottom line is that I had nothing to loose because it wouldn't work at all with the chunk missing.
Don
Miller Thunderbolt
Lincoln LE 31 MP
Lincoln 210 MP
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
