I have a polaris atv with a flat back rack (picture attached). The rack on the back is flat and plastic and I would like to build something with sides and also holder's for tposts that is removable. I don't want to remove the original plastic rack because I have a sprayer that hooks to it. Does any body have any ideas for a simple metal back rack which hooks to the original rack somehow, but has sides and a posts at each corner to hold tposts and/or strap something to. Anyone have any ideas? Thank you so much
ATV Rack, Need Help
Head to a local fab shop with a tube bender and take them the quad . Have them build one to your needs thats removal and light weight..
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Originally posted by jordan3215 View PostI have a polaris atv with a flat back rack (picture attached). The rack on the back is flat and plastic and I would like to build something with sides and also holder's for tposts that is removable. I don't want to remove the original plastic rack because I have a sprayer that hooks to it. Does any body have any ideas for a simple metal back rack which hooks to the original rack somehow, but has sides and a posts at each corner to hold tposts and/or strap something to. Anyone have any ideas? Thank you so much
[ATTACH]34625[/ATTACH]
would be a quick and simple solution...
They are pretty inexpensive and come in both steel and aluminum..
http://www.harborfreight.com/500-lb-...9623-8814.html
http://www.harborfreight.com/500-lb-...ier-92655.html
Originally posted by H80N View PostHave you considered getting one of the Horrible Fright hitch carriers... modifying and narrowing it by slicing and welding it??
HEY, THAT JUST MIGHT WORK!! Reasonably priced too.. Thank you!!!
Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
Originally posted by USMCPOP View Post
I did not even see that one....
GOOD FIND POP...!!!.
those hitch racks are nice but a 4 wheeler might ride a wheelie if you put any kinda wieght on it.if you go with the hitch rack yu might wanna throw a sand bag or two on the front rack to keep your wheels on the ground.
as for as the rear rack why not take the plastic one off and make a metal one then put the holes in it for the sprayer that way you'll have a dual purpose rack that will still fit any polaris attachments . if i'm right those polaris attachments work sorta like a boat plug if so just get a piece of pipe and use that as the holes and they should work great.i made a rack for a polaris ranger one time the rack fitted into the holes on the side of the bed we used some rubber pads we cut and stacked them on a bolt and when we tightened up the bolt it squeazed the rubber pads and widened out to grab inside the holes on the bed.
You could always cut off and remove the hitch tube then make the mounting points behind the seat...where the factory did it... that is where I was headed in the begining...
That is the beauty of being able to weld and fabricate.....
you can configure it any way you want.....
$100 from Polaris...http://www.polaris.com/en-us/atv-qua...er/pid-2878672MillerMatic 211 Auto-set w/MVP
Just For Home Projects.
Lots of possibles...
Originally posted by Doughboyracer View PostUmmmm... That's what he is/was asking for.
from his response....think he was looking at many broader possibles...
and that would be just one of them....
Seems like you can get these http://www.polaris.com/en-us/atv-qua...nt/pid-2876519
and make any kind of rack you want. I assume this is how the sprayer attachesGlen
Miller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45 - Hobart Handler 150
